chandankishor66
Find words within a column and relace it with with blank
Hello JMP community,
I want to remove ppm. from column 9 and store only numbers in column 10.
Can you please suggest any way to perform this task?
Many thanks,
Re: Find words within a column and relace it with with blank
Hi Chandan,
Assuming "ppm" is always the thing you want to remove, creating a new formula column to keep only the first word, while using "ppm" as a delimiter should work. Formula for this below:
Num(Word(1, :Column 9, "ppm"))
Using formula with Substitute() is one option (replace "851 ppm." with :Column 9)
Substitute("851 ppm.", "ppm.", "");
 Edit:
Might have to add Trim Whitespace()/Num() around substitute
Hi Chandan,
pauldeen
Create a new column with the formula:
Num( Regex( :Column 9, "\d+" ) )
\d means find valid digits. + means as many as possible. The whole result is type cast back into a number by the num() around it.
hogi
Level XIII
The regex version is nice.
If you don't want the rounded number:
Regex( :Column 9, "\d+,\d+" );
edited: as I just noticed that the numbers have comma as decimal separator
I think it's a good idea to have ponit as the standard in jmp and convert commas to points as soon as the file is loaded.
