jayv_
How to extract only numeric values out of text string
I have a large data table which has a  column containing char text.    An example of the text  description is  listed below.
I need to do some descriptive statistics on the duration to open/close for the robot.
I would like to extract the numeric portion of the character string and put it in a new column with numeric data type.
Is there a formula function I could use to do that  on a brand new column ?
Sample text
: Valve Movement to "CLOSE" position Completed. Time Taken for Movement "1.530000" Secs
: Valve Movement to "CLOSE" position Completed. Time Taken for Movement "2.030000" Secs
: Valve Movement to "CLOSE" position Completed. Time Taken for Movement "2.010000" Secs
: Valve Movement to "CLOSE" position Completed. Time Taken for Movement "2.510000" Secs
: Valve Movement to "CLOSE" position Completed. Time Taken for Movement "2.215000" Secs
: Valve Movement to "OPEN" position Completed. Time Taken for Movement "3.160000" Secs
: Valve Movement to "CLOSE" position Completed. Time Taken for Movement "1.815000" Secs
: Valve Movement to "OPEN" position Completed. Time Taken for Movement "3.140000" Secs
: Valve Movement to "OPEN" position Completed. Time Taken for Movement "2.955000" Secs
11 REPLIES 11
Re: How to extract only numeric values out of text string
This will work for the variable lengths
Num( Word( 1, SITEPOS, "XY" ) );
// and
Num( Word( 2, SITEPOS, "XY" ) );
jerryspilTC
Thank you :)
jerryspilTC
