jayv_
How to extract only numeric values out of text string
I have a large data table which has a  column containing char text.    An example of the text  description is  listed below.
I need to do some descriptive statistics on the duration to open/close for the robot.
I would like to extract the numeric portion of the character string and put it in a new column with numeric data type.
Is there a formula function I could use to do that  on a brand new column ?
Sample text
: Valve Movement to "CLOSE" position Completed. Time Taken for Movement "1.530000" Secs
: Valve Movement to "CLOSE" position Completed. Time Taken for Movement "2.030000" Secs
: Valve Movement to "CLOSE" position Completed. Time Taken for Movement "2.010000" Secs
: Valve Movement to "CLOSE" position Completed. Time Taken for Movement "2.510000" Secs
: Valve Movement to "CLOSE" position Completed. Time Taken for Movement "2.215000" Secs
: Valve Movement to "OPEN" position Completed. Time Taken for Movement "3.160000" Secs
: Valve Movement to "CLOSE" position Completed. Time Taken for Movement "1.815000" Secs
: Valve Movement to "OPEN" position Completed. Time Taken for Movement "3.140000" Secs
: Valve Movement to "OPEN" position Completed. Time Taken for Movement "2.955000" Secs
Jeff_Perkinson
Re: How to extract only numeric values out of text string
Hi JayV.,
The Word() function will also take an argument to specify the delimiters, so you can avoid the Substr() part of your formula and just use:
   Num( Word( 11, :Text, "\!" " ) )
The \! is the escape string to tell the parser that the " is part of the quoted string.
-Jeff
-Jeff
11 REPLIES 11
Depends upon EXACTLY what you want.  Does the following come close?
data have;
   input string & $100.;
   cards;
data want (drop=string both);
  set have;
  both=compress(substr(string,anydigit(string)),'"');
  num=input(substr(both,1,anyalpha(both)-1),12.);
  unit=substr(both,anyalpha(both));
run;
jayv_
Arthur,
     Thank you for your reply.   I started reading the Char functions help manual.
     I applied the following formula on my text column  which seemed to work.
     Num(Substr(Word(12, :Text), 2, 8))
     a) Extract  12th word from Text string   (i.e. "1.530000")
     b) Extract substring between quotations  (i.e. 1.530000)
     c) Convert character to numeric using Num function  (i.e. 1.53)
reeza
Try the scan function with the " as your delimiter.
scan(string, 4, '"')
Jeff_Perkinson
Hi JayV.,
-Jeff
-Jeff
jayv_
Your solution worked perfectly also.
I learnt something new with regards to escape string/delimiters. Thanks !
jerryspilTC
Hi I have a need to extract X & Y values from a text string & separate column, whats the formula? Thanks!
SITEPOS
X24Y34
X24Y35
X24Y36
X24Y37
X24Y38
X24Y39
X25Y34
X25Y35
X25Y36
X25Y37
X25Y38
X25Y39
X26Y33
X26Y34
X26Y35
X26Y36
X26Y37
X26Y38
X27Y33
X27Y34
X27Y35
jerryspilTC
Can we assume that the X and Y values are always two digits? If so, here is the formula for the X:
Num(Substr(:SITEPOS, 2, 2))
And here is the formula for the Y:
Num(Substr(:SITEPOS, 5))
Note that I converted both the X and Y values into numbers rather than leaving them as text.
Dan Obermiller
jerryspilTC
Hi Dan,
Thanks for prompt response. I have a mix of 2 & single digit sandwich inside the string.
SITEPOS
X14Y1
X14Y2
X14Y3
X14Y4
X14Y5
X14Y6
X15Y1
X15Y2
X15Y3
X15Y4
X15Y5
X15Y6
X0Y20
X0Y21
X0Y22
X0Y23
X0Y24
X0Y25
X1Y20
X1Y21
X1Y22
X1Y23
X1Y24
X1Y25
X18Y20
X18Y21
X18Y22
X18Y23
X18Y24
X18Y25
X19Y20
X19Y21
X19Y22
X19Y23
jerryspilTC
jerryspilTC
Hi Dan,
SITEPOS
X14Y1
X14Y2
X14Y3
X14Y4
X14Y5
X14Y6
X15Y1
X15Y2
X15Y3
X15Y4
X15Y5
X15Y6
X0Y20
X0Y21
X0Y22
X0Y23
X0Y24
X0Y25
X1Y20
X1Y21
X1Y22
X1Y23
X1Y24
X1Y25
X18Y20
X18Y21
X18Y22
X18Y23
X18Y24
X18Y25
X19Y20
X19Y21
X19Y22
X19Y23
jerryspilTC
