jyw
jyw
How to extract characters in occurrences of a certain character
for instance, I have a string of "JN-36M-GRNNC", I would like to extract "JN", "36M and "GRNNC" by using formula. The length between "-" is not fixed, can vary. I found an example on how to do it in Excel, https://www.ablebits.com/office-addins-blog/2015/10/07/excel-find-search-functions/. I wonder how to do it in JMP.
Thank you!
ron_horne
Re: How to extract characters in occurrences of a certain character
hi jyw​,
there are many ways of doing this pending on your further use. if there is always the same delimiter (such as "-") this method should do the trick.
otherwise it is not robust.
best,
ron
New Table( "Untitled",
       Add Rows( 1 ),
       New Column( "Column 1", Character, Nominal, Set Values( {"JN-36M-GRNNC"} ) ),
       New Column( "Column 2",
              Character,
              Nominal,
              Formula( Word( 1, :Column 1, "-" ) )
       New Column( "Column 3",
              Character,
              Nominal,
              Formula( Word( 2, :Column 1, "-" ) )
       New Column( "Column 4",
              Character,
              Nominal,
              Formula( Word( 3, :Column 1, "-" ) )
ron_horne
hi jyw​,
best,
ron
       Add Rows( 1 ),
              Character,
              Nominal,
              Character,
              Nominal,
              Character,
              Nominal,
jyw
jyw
hi Ron,
This is great, I got it working as expected, thank you so much!
