vincent_kane
Name Unresolved question
Dlg = Dialog  ("Select Grill",
vlist(Selection = listbox(GrillList),
button("OK")));
eval ( dlg [1]);
GrillSel = dlg ["Selection"];
Show( GrillSel );
An error popup message...Name Unresolved: Grillsel when GrillSel is used in a column formula.
Help is appreciated
Re: Name Unresolved question
Hi, Vincent.
There are a few things going on here.
1. Most importantly, the Dialog() function is deprecated.  I recommend that you convert to New Window() with the <<Modal option as described in the online documentation.
2. In the example you have provided, the result assigned to GrillSel is a list.  Most likely, you would need to extract the selected value from the list in order to use the value.
3. See JMP Usage Note 41824 for details regarding the use of a variable in a column formula.
I hope this helps.
Kind regards,
Wendy
Wendy
I am a bit confused.......but I will make a guess.  I get an error when the code is trying to find GrillList.
Assuming that GrillList is the name of a column in a data table, you will need to change the reference to it, to get the values from the data table
vlist(selection - listbox(:grillList<<get values),
vincent_kane
Jim:
Here is the script. When I use GrillSel in a column formula I get the error message. However, I do see the value of GrillSel in the log after a selection is made.
dt = datatable("Sales w Corrosion Updated");
GrillList = AssociativeArray(Column(dt, "Grill") << getValues) << getKeys;
SaleYrList = AssociativeArray(Column(dt, "Sales Year") << getValues) << getKeys;
ClaimYrList = AssociativeArray(Column(dt, "Global Year") << getValues) << getKeys;
PartList = AssociativeArray(Column(dt, "grill parts") << getValues) << getKeys;
button("OK")));
eval ( dlg );
Show( GrillSel );
Hi, Vincent.
I hope this helps.
Kind regards,
Wendy
Wendy
