  • Due to inclement weather, JMP support response times may be slower than usual during the week of January 26.
    To submit a request for support, please send email to support@jmp.com.
    We appreciate your patience at this time.
OddsDeer284888
How to display dynamic Data Filter in JMP Live?
We are currently using a custom UI for local setup, but now we want to have a similar setup on JMP Live.
I realized that JMP Live doesn’t work with custom UIs. What options do I have to achieve the same or a similar result?
The current UI filters and creates subsets in a specific format for the end user.
Is it possible, through Data Filter or some other method, to achieve the same functionality on JMP Live? I tested this with Big Class.jmp, but it only uploads and displays the data table on JMP Live, without applying the filtering.
dt << Data Filter(
Add Filter(columns(:sex, :age))
15 REPLIES 15
Eric_Hill
Re: How to display dynamic Data Filter in JMP Live?
Hey, @OddsDeer284888 ,
For ODBC to work in JMP Live, the ODBC connection needs to use a DSN-less connection. If you publish a data table from JMP that has a source script that uses ODBC, that script will automatically be modified during the publish process to use a DSN-less connection (so it will have driver/server in it rather than a DSN). That's step one.  Then, when you make a refresh script for that data table, if you start from the source script, you'll be most of the way there. You will probably have to attach credentials to it.
Step two is to make sure that the ODBC driver that the script uses is installed on the computer that is running the JMP Pool. You may need to talk to your JMP Live administrator about making that happen.
If you run into further problems getting this to work, start a case with JMP Tech Support and we'll make sure to help you get it working.
Good luck,
Eric Hill
OddsDeer284888
thank you for your comment.
Did you mean the script that the JMP Live auto generate for the Data Table after we publish the data to JMP Live?
And do you have an example code for the dsn-less query to make connection or test connection for the data  refresh?
As with local JMP we are querying it directly like this:
::DB_CONNECTION_STRING = "DSN=testConnection";
    dt_results = Open Database(
        DB_CONNECTION_STRING ,
        "SELECT
        FROM TestTable
        WHERE key IS NOT NULL",
        "Test Table"
What exactly needs to be included in the DSN‑less connection string?
Or should we rely on the auto‑generated refresh script that JMP Live creates during publishing?
OddsDeer284888
Open Database(
	"DSN=testConnection;",
	"SELECT
            FROM TestTable
	"Test Table"
this is the example script that the Source generates.
if we wanted to utilize the above script and use variable instead then the correct format to pass the credentials would be like this? Or is their anythign else needs to be added?
"DSN=testDSN;" ||  // same name as DSN in the credentials
"UID=%_UID_%;" ||
"PWD=%_PWD_%;";
You need to ensure that the server where JMP Live resides has the same exact DSN and Driver installed on it that you have setup on your machine. You'll need to work with your internal JMP Live support team to have them install the driver.
HTH,
Bobby
OddsDeer284888
If the JMP Live server has also the same DSN and Driver installed then is there anything specific needs to be passed in the query to get up-to-date data over there?
You'll need to pass the DB name, driver, port, server and user credentials (as placeholders).
Here's an example script to query data:
dt = New SQL Query(
       Connection(
			"ODBC:DATABASE=placeholder;
			DRIVER={placeholder};
			PORT=placeholder;
			PWD=%_PWD_%;
			SERVER=placeholder;
			UID=%_UID_%;"
       QueryName( "placeholder" ),
       Select,
       From( Table( "placeholder", Schema( "placeholder" ) ) )
) << Run Foreground;
dt;
