hogi
Level XIII
Journal: JSL block
How can I add a Block with JSL code (like in a JMP notebook) to a Journal ?
Re: Journal: JSL block
This should do it for you
names default to here(1);
jr=new window("the journal",<<journal);
nb = Notebook();
block = nb <<
Add New Block(
	"JSL"
theWindows = ( Get Window List() << Get Window Title() );
jr << append(window(thewindows[nitems(thewindows)]));
window(thewindows[nitems(thewindows)])<<close window;
nb = Notebook();
block = nb <<
Add New Block(
	"JSL"
hogi
Level XIII
Ah, thanks!
One has to paste the hole "Window", not just the JSL "Code Block" ?!
The Buttons are missing in the Journal.
This is ok, one can still run the code via right click.
hogi
Level XIII
Hm, at the moment, I just need it for JSL code. ->  I will use a standard Script Box ...
(view in My Videos)
