How to detect the points of an image outline on Graph Builder
I have a JMP data table (attached) with coordinates (X/Y columns) and a variable of interest (COLOR) that I use to create a gradient plot.
In the background, I add a transparent image to see how my variable of interest is distributed across my image. The problem is that I would like the transparent gradient plot to automatically display only on the points in my image and for the background to remain black. I don't know how to detect the points in the image.
Have you ever encountered a similar case?
hogi
Level XIII
Re: How to detect the points of an image outline on Graph Builder
load the image as a data table into JMP, e.g. via Image to Table from the Marketplace:
select a point in the background, select matching cells - > create subset
align the x/y scale with the scale of the other data table.
merge the tables - use the "mask" as a mask (e.g. via exclude)
hogi
Level XIII
Thank you it was exactly what i wanted !
