plkx
How to create summary stats table with original columns and stats in rows?
This seems like it should be trivial, but I've not found a way to accomplish the goal (so far - I'm relatively new to JMP but have spent significant time looking for this).
I have a large data table with 1779 columns, the first of which contains substance names, and the remaining 1778 (variables) contain numeric data for continuous modeling.
I need summary stats in a table that mirrors the columns in the original table, with the first column containing rows of the various summary stats (let's say these: N, N missing, min, max, range, median, mean, geometric mean, variance and standard deviation).
I want to use the summary stats to pick variables from the original columns (and to remove irrelevant variables altogether).
It seems silly to resort to Excel (which I don't totally trust for stats), only to transfer it all back to JMP, to Fit Y by X, etc.
Thanks,
PL
plkx
Re: How to create summary stats table with original columns and stats in rows?
Apparently, I just needed to reveal my ignorance before I was able to do this using tabulate by dragging each stat.
It would be nice to just have check boxes, or choose stats by highlighting them.
At least I can now move on...
plkx
