How to create deciles in JMP Pro 12?
I have a set of scores derived from a model and I want to categorize these predictive scores into decile. How do I go about doing that?
Jenkins Macedo
scwise
Re: How to create deciles in JMP Pro 12?
See if this helps with using the add-in for quantile column creation...I attached a few screen shots below.
This is my favorite way to do quantiles as you will have a ready quantile column created for anlaysis and graphing!
Once you identify the column, use the Set Cutpoints At Percentiles option from the Interactive Binning red triangle.
Then put in 10 to get every decile and put in the labels you want to see in the column.
Then use the Save Group Column to get the formula created back to your datatable!10582_Screen Shot 2015-12-03 at 9.55.26 AM.png10582_Screen Shot 2015-12-03 at 9.55.26 AM.png
10583_Screen Shot 2015-12-03 at 9.59.21 AM.png10583_Screen Shot 2015-12-03 at 9.59.21 AM.png
12 REPLIES 12
Jeff_Perkinson
Perhaps Interactive Binning​ would help.
It will set cut points based on percentiles.
-Jeff
-Jeff
I just downloaded the app and trying to follow the instructions
Jenkins Macedo
KarenC
Or just use distribution then from the red triangle: Display Options>Set Quantile Increment and enter the increment you desire and your Quantiles output will be updated with the desired quintiles.  You can't save the quantiles as you can with the add-in (developer nudge - but I would like the option to save the quantile group).
Sounds good. I will try both options. I want the data to be portray into ten deciles with the 1st decile of those who contain the highest predictive score and the 10th decile with those of the lowest predictive scores. Make sense?
Jenkins Macedo
scwise
Scott, this is exactly what I needed and went bye like wind using the Interactive Binning. Perfect guys!
Jenkins Macedo
10584_Decile Results on Stepwise Regression Scores.jpg10584_Decile Results on Stepwise Regression Scores.jpg
Jenkins Macedo
I just displayed the decile created into distribution and it appears the 3rd and 4th decile are missing even though they appear in the formula. Could there be no records were allocated to these two decile when I entered 10 when specifying the percentile?
Jenkins Macedo
Jenkins Macedo
