euge
How to create column names based off a list?
I have a list comprised of stringlist={Albert,Bert,Cathy ,Daniel,Total} that are column names in a table
I'd like to create in the same table 4 new columns, with new column names Albert Total,Bert Total,Cathy Total, Daniel Total where the formula of Albert total = Albert/Total, Bert = Bert/Total, etc
The column names albert, bert, cathy, daniel can be variable, but the column name total is always the same.
Here's what I tried:
for(i=1,i<=nitems(stringlist),i++,
     dt<<new column name(eval(stringlist)||" Total",
          formula((eval(parse(stringlist))/:total)
I've tried variants of evallist, evalexpr, parse with no avail...
pmroz
Re: How to create column names based off a list?
This will do the trick:
dt = New Table("Untitled", Add Rows( 5 ),
   New Column( "Albert", Numeric,
        Continuous,    Format( "Best", 12 ), Set Values( [1, 2, 3, 4, 5] )    ),
    New Column( "Bert", Numeric, Continuous, Format( "Best", 12 ),
        Set Values( [6, 7, 8, 9, 10] )),
    New Column( "Cathy", Numeric, Continuous, Format( "Best", 12 ),
        Set Values( [11, 12, 13, 14, 15] )),
    New Column( "Daniel", Numeric, Continuous, Format( "Best", 12 ),
        Set Values( [16, 17, 18, 19, 20] )),
    New Column( "Total", Numeric, Continuous, Format( "Best", 12 ),
        Set Values( [23, 43, 222, 32, 444] )),
stringlist = dt << get column names (string);
For( i = 1, i <= N Items( stringlist ), i++,
    one_col = stringlist[i];
    if (one_col != "Total",
        new_col = one_col || " Total";
        col_string = "dt << new column(new_col, formula(:" || one_col || " / :Total))";
        eval(parse(col_string));
euge
Cool!  I was trolling thru the solutions, and was using the below solution (in case anyone else is curious) - yours is better because it doesn't rely on column position...
nlist=ncols(dt)
cols=dt<<get column names;
totals=column("total")<<get as matrix;
for(i=1,i<=nlist-1,i++,
  newcolexpr=expr(
  dt<< new column( char(cols)||"_Total",numeric,formula(expr(cols))/expr(totals))));
  Eval(eval expr(newcolexpr));
