amitkb
Model target=1 instead of Target=0 in Nominal Logistic Regression
Hi all,
           In fitting a Nominal Logistics Regression, JMP models Target=0. I want to model target=1 and get the parametric estimates for the factors.
           How can i do this.
           I appreciate all your help.
Regards,
Amit Bothra
amitkb
Re: Model target=1 instead of Target=0 in Nominal Logistic Regression
Hi Anca,
              I found the way to model target=1.
         In your data table, right click on the Target column and under column properties there is an option Value Ordering. You need to put the value 1 before 0. This will do the trick.
         I appreciate your effort in helping me.
Regards,
Amit
ancatilea
Hi.
I am not sure if this applies/works in JMP
but there is an option in the
     PROC LOGISTIC data = your_data DESCENDING;
          model y = x1 x2;
     run;
Maybe this helps?
amitkb
Hi Anca,
               Thanks for the reply.  In SAS its easy and there are multiple ways.
           In JMP its wizard driven, so trying to figure out.
Regards,
Amit Bothra
ancatilea
Maybe this helps...(as I am completely unfamiliar with JMP)
Here is an extract from :
Logistic Fit Platform Options
For binary responses, the log odds ratio for flipped response levels involves only changing the sign of the parameter, so you might want the reciprocal of the reported value to focus on the last response level instead of the first.
Does this help?
amitkb
Hi Anca,
Regards,
Amit
