How to create a interactive HTML with two tabs which change the chart image in one based on the value choosen in dropdown list
rpt = New Window("Image Gallery Report",
TabBox("Overlay Maps",
    H List Box(
        row1_hlist = V List Box(Text Box("Image Gallery from: " || "INTW.203P"),
        //Text Box("Found " || Char(N Items(image_files)) || " images"),
        Spacer Box(Size(0, 10))),
        Spacer Box(Size(0, 20)),
        // Second row label
        row2_hlist = V List Box(Text Box("Image Gallery from: " || "INTW.103P"),
    "Indiviudal",
    H List Box(
         // Second row label
        row3_hlist = V List Box(Text Box("DROPDOWN "),
        myListbox = ComboBox(Lot_List, doListChoice),
        doListChoice = expr(
choice = myListbox << getSelected;
show(choice););
        Spacer Box(Size(0, 10)),
        report_conatiner = v list box()
        // Second row label
        row5_hlist = V List Box(Text Box("Image Gallery from: " || "INTW.103P")
I have got the report from above script but its not interactive and I am getting access error on report conatiner. Could you please help
	Tab Box(
		"Overlay Maps",
		H List Box(
        // Second row label
		"Indiviudal",
		H List Box(
         // Second row label
				myListbox = Combo Box(Lot_List, doListChoice),
				doListChoice = Expr(
					Show(choice);
				Spacer Box(Size(0, 10));,
				report_conatiner = V List Box()
        // Second row label
Edit (jthi): added JSL formatting and removed some unnecessary whitespace
Re: How to create a interactive HTML with two tabs which change the chart image in one based on the value choosen in dropdown list
For interactive html you usually have to create separate plots. For grouping I tend to utilize Tab Box
dt = open("$SAMPLE_DATA/Big Class.jmp");
gb1_expr = Expr(dt << Graph Builder(
	Show Control Panel(0),
	Variables(X(:weight), Y(:height), Overlay(:sex)),
	Elements(Points(X, Y, Legend(9)), Line Of Fit(X, Y, Legend(11)))
gb2_expr = Expr(dt << Graph Builder(
	Variables(X(:weight), Y(:height), Overlay(:age)),
nw = New Window("My Report",
	tb = Tab Box(
		Tab Page Box("Report1",
			gb1_expr
		Tab Page Box("Report2",
			gb2_expr
tb << Set Selected(1);
nw << Save Interactive HTML("$TEMP/DELETEME.html");
wait(0);
nw << close window;
Web("$TEMP/DELETEME.html"); // open for demo purposes
And if you really want to "force" that type of selections, you can do it with some html and javascript
I don't think you can have that type of functionality by just using JMP as most of the controls are not interactive in the html. You do have some limited capabilities with local data filter
gb = New Window("", dt << Graph Builder(
	Size(525, 454),
	Elements(Points(X, Y, Legend(3))),
	Local Data Filter(
		Mode(Include(0)),
		Add Filter(columns(:sex), Display(:sex, N Items(2)))
gb << Save Interactive HTML("$TEMP/deleteme.html");
wait(0);
gb << Close Window;
Web("$TEMP/deleteme.html");
If I have had need for something special like this, I have generally done it by using html + javascript which loads the pre-created JMP reports to iframe or something similar.
8 REPLIES 8
One more issue on the above script is in JSL report tab is creating but not in HTML report with below code
rpt << Save HTML("BSS.HTML", "BSS Report");
Not all the features work within interactive html and you might have to use different structure.
Level XIII
Interactive Tabbed reports in 5 seconds - without issues?
-> use Application Builder
Scripters Club 2024: Session 1 - Application Builder by @DonMcCormack
One Multi-tabbed, Filterable Dashboard (2021-US-30MP-803)
Thanks Jarmo. Is it possible to create HTML report with dropdown box and change graph based on value chosen from dropdown box?
Level XIII
To get a Dropdown menu instead of Tabs, you can change the "Style" to "Combo":
edit:
but the exported HTML file doesn't use this setting - it will use Tab mode again:
	tb = Tab Box(
			gb1_expr
			gb2_expr
wait(0);
nw << close window;
This is great thanks a million Jarmo. Is it possible to have button functionality to be work on HTML or it has to just Jmp report.
	Size(525, 454),
	Local Data Filter(
		Mode(Include(0)),
wait(0);
gb << Close Window;
