MWalther
size of Text Edit Box
I have a script, requesting a comment  from the user.
I use a text edit box, but cannot modify the length of the box (on the screen).
Any Idea how to set a value for the length (like 40 characters, 2 lines, ...) since I want the user to type in detailed comments
example:
H List Box(
     Text Box( "Type in  comment: " ),
      teb = Text Edit Box( initial_text)
Spacer Box( size(1, 10) ),
H Center Box(.....
Edit (jthi): added jsl formatting
mmarchandFSLR
Re: size of Text Edit Box
I believe width of Text Edit Boxes is always set in pixels.
New Window( "text test", Text Edit Box( "", <<Set Width( 250 ), <<SetNLines( 2 ), <<Set Hint( "This is a text box you\!Ncan edit!" ) ) );
mmarchandFSLR
