eric_laloum
How to create a curve from a line ?
Hi all,
I'm using JMP 13.1.0.
I have a dataset with each sample being a spectrum and each column being a wavelength.
I would like to plot all the samples within one graph, just what I get within Excel, but I can't find the way to do that.
I'm aware that there is a spectra tool developed for version 16, but anyway, I would like to do so in my version 13.
I attached the datafile in JMP as well as the output in Excel, which I would like to have also within JMP !
Thanks for your help,
Eric
Re: How to create a curve from a line ?
1. Create new column which indicates the row number
2. stack your numerical columns
3. Create graph builder with your new data
using row as overlay and label as x-axis (change data/modeling types as you want them to be)
scaled to quite similar as your excel image
You might consider using the Functional Data Explorer in JMP Pro. It is designed to work with functional data, curves, profiles, and such data. This tool plots the curves, provides many useful pre-processing steps, and fits several models that are then used to extract functional principal components for further analysis in the X or Y role. For example, as Y, you can perform functional DOE to determine how to set factors to optimize the curve shape.
