dn610
JMP Scripting_Adding Pop Up Window
Is there a way to create a pop up with a customized message for any instance where there is an error and the JMP script can't continue running? Along the same lines, is there a way to create a pop up to say that the script is done running?
Re: JMP Scripting_Adding Pop Up Window
Modal Dialogs might be a good read.
