BookmarkSubscribeRSS Feed
markschahl
Jun 18, 2012
How to copy value colors to row state
I have manually assigned column value colors through column properties. Is there a way to copy the value color scheme to the row states via scripting? I tried the following, but it  didn't work since the get property returns a list:
For Each Row(Color of(row state(row()))= :PolyGrade <<get property("Value Colors"));
markbailey
Jun 23, 2011
Solution
Re: How to copy value colors to row state
Try this:
:age << Set Property( "Value Colors", {12 = -13977687, 13 = -3780931, 14 = -4222943, 15 = -13596966, 16 = -2211217, 17 = -10562780} );
value color property = :age << Get Property( "Value Colors" );
For( i = 1, i <= N Items( value color property ), i++,
value = Arg( value color property[i], 1 );
color = Arg( value color property[i], 2 );
target = dt << Get Rows Where( :age == value );
For( r = 1, r <= N Rows( target ), r++,
Row State( target[r] ) = Color State( color );
markbailey
Jun 23, 2011
Solution
Try this:
markschahl
Jun 18, 2012
Thanks, Mark. That worked. I did not know about the Arg() function.
I also found out that once Value Colors column property is set, this will work: dt<<Color or Mark by Column( :ColName )
