See how to use JMP Live to centralize and share reports within groups. Webinar with Q&A April 4, 2pm ET.
How to convert a numeric list into a character one?
anne_sa
Hi everybody,
I have a list containing numbers and I would like to transform them into characters. Is there a way to do that without using a loop? I was not able to find the proper function.
Thanks for your help!
Jeff_Perkinson
Re: How to convert a numeric list into a character one?
New in JMP 16 is the For Each() function which iterates over a container – list, matrix, or associative array – to perform an operation on each element.
Here is an example to show how to use it to convert your list of numbers to a list of character strings.
theList = {7, 8, 9};
For Each( {value, index}, theList, theList[index] = Char( value ) );
-Jeff
13 REPLIES 13
Here is a little script that creates a function that does what you want.  You can either define and use the function in your code, or use the 4 statements in open code to do the conversion.
theList = {7,8,9};
NumListToChar = Function( {myList},
	{defaultlocal},
	dtx = New Table( "x", New Column( "y", values( myList ) ), private );
	dtx:y << data type( character );
	myList = dtx:y << get values;
	Close( dtx, nosave );
	Return( myList );
theList = NumListToChar( theList );
anne_sa
Thanks for your answer @txnelson it is indeed what I was looking for.
I just wonder what is the faster between a loop and a function which involves table creation. Any idea?
Jeff_Perkinson
-Jeff
anne_sa
Thanks @Jeff_Perkinson !
I did some simulations just by curiosity to compare the execution time of each solution and it seems that the for each function is on average the fastest one!
So I am gonna pick that one although the function of @txnelson also works very well.
Thanks to both of you
Jeff_Perkinson
Here's a quick timing program for the three methods, for loop, for each, and custom function using data table.
listsize=1000000;
theList = As List( J( listsize, 1, Random Integer( 100 ) ) );
	{defaultlocal},
	Return( myList );
start = HP Time();
foreachloop = HP Time() - start;
start = HP Time();
customfunction = HP Time() - start;
start = HP Time();
For( i = 1, i <= N Items( theList ), i++,
	theList[i] = Char( theList[i] )
forloop = HP Time() - start;
show(foreachloop, customfunction, forloop);
For me with the listsize shown above the results are very similar between the three methods:
foreachloop = 1106974;
customfunction = 1077862;
forloop = 1400643;
-Jeff
Extending Jeff's answer
Different overheads hurt for small sizes and help for large sizes.Different overheads hurt for small sizes and help for large sizes.
dt = New Table( "Untitled 3",
	Add Rows( 0 ),
	New Column( "size", Numeric, "Continuous", Format( "Best", 12 ), Set Values( [] ) ),
	New Column( "for", Numeric, "Continuous", Format( "Best", 12 ), Set Values( [] ) ),
	New Column( "foreach", Numeric, "Continuous", Format( "Best", 12 ), Set Values( [] ) ),
	New Column( "custom", Numeric, "Continuous", Format( "Best", 12 ), Set Values( [] ) )
	{defaultlocal},
	Return( myList );
For( listsize = 1, listsize < 1e7, listsize *= 2,
	start = HP Time();
	start = HP Time();
	start = HP Time();
	Show( foreachloop, customfunction, forloop );
	dt << addrows( 1 );
	dt:size[N Rows( dt )] = listsize;
	dt:for[N Rows( dt )] = forloop / 1e6;
	dt:foreach[N Rows( dt )] = foreachloop / 1e6;
	dt:custom[N Rows( dt )] = customfunction / 1e6;
	Wait( 0.1 ); // so it shows on display
anne_sa
Thanks for the additional information @Jeff_Perkinson and @Craige_Hales !
We always learn a lot of things with the Community!!
ms
Super User (Alumni) ms
Nice illustration of the size-dependent performance of the different functions. I'm still using JMP 15 and can't use For Each() yet, but to extend Jeff's timing exercise further I toss in two more functions that give the same result.
Repeat(k = 0; {k++; Char( theList[k] )}, listsize);
Words( Substr( Char( theList ), 2, Length( Char( thelist ) ) - 2 ), ", " );
The For loop, which is the fastest for small lists, is surpassed by Words at size>50, by the data-table-detour function at size>1000 and by Repeat at size>30000.
I was a little surprised to see that Words remained the fastest for size>50, about twice as fast at millions of "words".
anne_sa
Wow I was looking for one solution and I got so many! JMP is amazing! Thanks all of you!
