miguello
How to convert a number to string using specific format? For instance: {"Scientific", 12}
As a subject suggests, I need to convert a number to string using a specific format. To be precise: I have a handle on GB plot, and Text() near that handle that outputs current coordinates of the handle:
Text( Erased, {box:exx, box:exy} + box:axisRange * 0.01, "(" || Char( Round( box:exx, 2 ) ) || "," || Char( Round( box:exy, 2 ) ) || ") " ) ;
On some plots the Y Axis is very small and is displayed in Scientific format:  {"Scientific", 12}
The idea is to grab the format from the axis (both of them) and format corresponding coordinates written in the Text() accordingly (instead of doing Round(xyz, 2).
I tried a few different approaches, but they all error out.
Any suggestions?
Level XIII
Re: How to convert a number to string using specific format? For instance: {"Scientific", 12}
Hi @miguello , you can use
Format(value, "Scientific", width, decimals)
Ok, it might be version dependent then (I tried with JMP18/19). The sure way of doing this is using something like hogi did already demonstrate with the substitute+insert.
f = {"Scientific", 12};
bb = 3.1415926535;
myval_format = Insert(f, bb, 1);
myval_str = Eval(Substitute(myval_format, {}, Expr(Format())));
Level XIII
miguello
Ok, I tried it like below and it worked:
  aa = rgbs << XPath("//AxisBox");
  format1 = aa[1][2] << Get Format;
  format2 = aa[2][2] << Get Format;
  bb = 3.1415926535;
  Format(bb, format1[1], format1[2], format1[3]);
  Format(bb, format2[1], format2[2], format2[3]);
I have two GBs, Pulling formats from them yields:
{"Scientific", 12}
{"Fixed Dec", 12, 2}
When using as I showed it correctly formats the number, even though format1 has only two members in the list. I guess it has an internal Try() or something.
"3.1415927e+0"
"3.14"
Any way to just use pulled format without spelling it by member?
Level XIII
Many unnamed arguments in Jmp are optional.
You need to insert the value .
As an alternative you can use
Insert (Substitute(format1,{},Expr(Format())),expr(value),1)
It looks much more complicated. The benefit:
Independent of the number of settings.
Another approach: inverting the 2 steps
Substitute(insert({value},format1),{},Expr(Format()))
One of the few cases where it helps that Insert flattens the result:
 JMP Expr() weirdness, can anyone explain?
For all the other cases, I hope Insert will get a new option ; )
Insert Into: Flatten(0|1)
Have you just tried using the list of the parameters?
gb = dt << Graph Builder(
	Size(525, 454),
	Show Control Panel(0),
	Variables(X(:weight), Y(:height), Overlay(:sex)),
	Elements(Points(X, Y, Legend(9)), Line Of Fit(X, Y, Legend(11))),
		Dispatch({}, "weight", ScaleBox, {Format("Scientific", 12)}),
		Dispatch({}, "height", ScaleBox, {Format("Fixed Dec", 12, 2)})
abs = gb << XPath("//AxisBox");
xaxis_format = abs[1] << get format;
yaxis_format = abs[2] << get format;
bb = 3.1415926535;
Show(Format(bb, xaxis_format)); // Format(bb, xaxis_format) = "3.1415927e+0";
Show(Format(bb, yaxis_format)); // Format(bb, yaxis_format) = "3.14";
miguello
For some reason that doesn't work in my case:
  bb = 3.1415926535;
  Show(format2);  //format2 = {"Fixed Dec", 12, 2};
  Show(Format(bb, format2)); //Format(bb, format2) = "01/01/1904";
I'm on JMP 17.2
bb = 3.1415926535;
