BabyDoragon
Regarding the issue of generating dynamic variable names using nested loops
Regarding the dynamic variable issue, here is the JSL below. I want to generate variable names combining fruit and month, for example, Apple_Jun. However, the following JSL does not run. How should I fix it?
FruitList = {"Apple", "Banana", "Cherry", "Durian", "Entawak"};
MonthList = {"_Jan", "_Feb", "_March", "_April", "_May"};
For( count = 1, count <= N Items( FruitList ), count++,
	For( countM = 1, countM <= N Items( MonthList ), countM++,
		ex = Expr(
			Parse( Fruit || Month ) = 1;
		Substitute Into( ex,
			Expr( Fruit ), FruitList[Count],
			Expr( Month ),
				MonthList[CountM]
	Eval( ex );
Show( Apple_Jan );
Re: Regarding the issue of generating dynamic variable names using nested loops
You have made the JSL far more complex than required
ColNamesList = {};
For Each( {Month}, MonthList,
	For Each( {Fruit}, FruitList,
		Insert Into( ColNamesList, Fruit || Month )
Show( ColNamesList );
lwencx
hogi
Level XIII
One of the few places where Parse() is needed - and there seems to be no easier approach via Expression handling:
generation of variable names.
On the other hand:
In 99% of such cases, one can zoom out one step and search for an easier approach for the main target.
One which doesn't rely on custom made variable names.
e.g. use a 2D array, nested lists or associative array of associative arrays.
fruit_month
and indexing like
fruit_month[i,j], (fruit_month[i])[j] or (fruit_month[month])[fruit]
instead of a "2D-Array" of variable names.
There are very very limited cases where you might generate dynamic variable names and usually even with those, you shouldn't. Instead, consider using proper data structure (table, associative array, lists, ...).
Example using associative array
aa = Associative Array(FruitList, Repeat({Associative Array(MonthList, As List(Repeat(1, N Items(MonthList))))}, N Items(FruitList)));
aa = Associative Array();
For Each({fruit}, fruitlist,
	For Each({month}, monthlist,
		If(!Contains(aa, fruit),
			aa[fruit] = Associative Array();
		aa[fruit][month] = 1;
Show(aa["Apple"]["_Jan"]);
Difficult to read version
