lwx228
Level VIII
How to compute a match with JSL?
Hello, everyone!
In excel, "=offset(,match(,,)-1,match(,,)-1,,)" functions can be used to calculate, but the speed is slow when the data is large.
ih
Super User (Alumni) ih
Re: How to compute a match with JSL?
Here are a few ways, to stack with a variable number of columns, if you are using match in excel today then one of the first two methds will likely work:
//If the column positions do not change
d3_1 = d1 << Stack(
	columns( Concat( [2 3], 4::10 )),
	Source Label Column( "year" ),
	Stacked Data Column( "data" ),
	Drop all other columns( 1 ),
	Keep( :state )
//If you want all columns
d1_clean = ( d1 << Subset( All rows, columns( 1::10 ) ) );
d3_2 = d1_clean << Stack(
	columns( 2:: ncol(d1_clean) ),
	Keep( :state )
//If the column names are in a specific format
// - get column names
cn = d1 << Get Column Names( string );
// - Find which columns match a format
//   (jmp does have some patter matching tools but I like regex, check out regexr.com)
matches = repeat(0, N Items(cn));
for(c=1, c<= N Items(cn), c++, if(!is missing(Regex(cn[c], "^\d+$")), matches[c] = 1));
// - Stack
d3_3 = d1 << Stack(
	columns( loc(matches) ),
	Keep( :state )
9 REPLIES 9
lwx228
Level VIII
d1 = Open( "$SAMPLE_DATA/Presidential Elections.jmp" );
d2 = New Table( "offset",
Add Rows( 8 ),
New Column( "State",
Character,
"Nominal",
Set Values(
{"Wyoming", "Montana", "Montana", "Alaska", "Wisconsin", "Nebraska", "Nevada", "Montana"}
New Column( "year",
Character,
"Nominal",
Set Values( {"1988", "1988", "1988", "1992", "2000", "1992", "2004", "1980"} )
New Column( "data", Character, "Nominal", ),
lwx228
Level VIII
Calculate the value of "data" in table "offset" based on the data in table "Presidential Elections".
Thank you!
ih
Since you are worried about speed with large tables, you might create a 'lookup table' in a long format so there is one row per value and then use with Join or Update to do the lookup.  Here is how that might look:
Names default to here( 1 );
	Add Rows( 8 ),
		Character,
		"Nominal",
		Set Values(
	New Column( "year",
		Character,
		"Ordinal",
	New Column( "data",
		Numeric,
		"Continuous",
		Format( "Fixed Dec", 12, 1 ))
//Move data to a long format
d3 = d1 << Stack(
	columns(
		:Name( "1980" ),
		:Name( "1984" ),
		:Name( "1988" ),
		:Name( "1992" ),
		:Name( "1996" ),
		:Name( "2000" ),
		:Name( "2004" ),
		:Name( "2008" ),
		:Name( "2012" )
d3 << Set Name( "Long format" );
d3:year << Set Modeling Type("Ordinal");
//'Lookup' the values:
d2 << Update( with(d3), Match Columns( :state=:state, :year=:year ), Add Columns from Update table( None ));
d3 << Close window;
lwx228
Level VIII
good job !Thank you!
lwx228
Level VIII
If these columns are many, such as more than 1000……Let's say it's a date.
how do these columns implement the d3 table setup in the form of a variate loop.Thank you!
ih
d3_1 = d1 << Stack(
	Keep( :state )
	Keep( :state )
// - Stack
d3_3 = d1 << Stack(
	Keep( :state )
lwx228
Level VIII
Thank you very much for your help.
It's also quick to use a dictionary in excel……Set d = CreateObject("Scripting.Dictionary")
but more than a million lines will have to be done differently.
I don't see the benefit to the JMP User Community of the statement in your last reply,
     "It's also quick to use a dictionary in excel……Set d = CreateObject("Scripting.Dictionary")"
It seems that such a comment would be more appropriate on the Excel Discussion Forum
lwx228
Level VIII
Yes, excel is convenient to use worksheet functions within 10,000 rows.
Over 10,000 rows I'm used to doing this with a VBA dictionary.But dictionaries over 100,000 are slow.
Now using this method of JMP, over 10 million lines are also fast.ThankS you!
