aravindan880
How to combine reports from two attribute charts into one report?
I Have generated two Attribute charts using the following codes
Attribute Chart(
  Y( :Part ),
  X( :Attribute GRR Part ),
  Standard( :Standard ),
  Effectiveness Report( 1 ),
Attribute Chart(
  Y( :Kappa Results ),
  X( :Kappa Parts ),
  Standard( :Kappa Standard ),
  Attribute Gauge Chart( 0 )
In each chart there is some report which i want to extract
First chart        Second chart
I want to extract the Effectivenss Report and comformance report from the first chart and the effectiveness report from the second chart and combine in one  Data table.
Re: How to combine reports from two attribute charts into one report?
Here is a script that produces the following output:
att1 = dt << Attribute Chart(
      Y( :Part ),
att2 = dt << Attribute Chart(
      X( :Kappa Parts ),
Results List 1 = {};
Results List 1[1] = (Report( att1 )["Effectiveness"][1][1][2] << get)[1] / 100;
Results List 1[2] = (Report( att1 )["Conformance Report"][1][1][1][2] << get)[1];
Results List 1[3] = (Report( att1 )["Conformance Report"][1][1][1][3] << get)[1];
Results List 2 = {};
Results List 2[1] = (Report( att2 )["Effectiveness"][1][1][2] << get)[1] / 100;
New Window( "test",
      tb1 = Table Box(
            String Col Box( "GRR", {"Effectiveness", "False Alarm", "Miss Rate"} ),
            nb1 = Number Col Box( "Results", Results List 1 )
      tb2 = Table Box(
            String Col Box( "Kappa", {"Effectiveness"} ),
            nb2 = Number Col Box( "Results", Results List 2 )
tb1 << set column borders( 1 ) << set row borders( 1 );
tb2 << set column borders( 1 ) << set row borders( 1 );
nb1 << set format( "Percent", 7, 2 );
nb2 << set format( "Percent", 7, 2 );
what I don't know is if the two attribute platform runs are both run on the same data table or on separate tables.  If they are on separate tables, you will need to add a second pointer to the second table, and change the reference to it where required in the script, so that the attribute platform is run against it.
Your request about putting the results into a data table can not be accommodated.  Columns in a JMP data table can not contain numeric and character data.  Your sample has a second column that has both the Character value of "Results" and also numeric values.  A JMP data table is an analysis data structure, not just a spreadsheet like Excel, where every Cell is an independent structure.
If you look at the output that I am giving you, it is also broken into 2 separate Table Boxes, but displayed together.  It was done this way, for the same reason as the data table requirement..
Here is a script that will take the components you specified, and place them into a new display window.  You specified you want to combine them into one "Data Table".  Could you please give more details on what this request really is?
att1=Attribute Chart(
  Y( :Part ),
  Effectiveness Report( 1 );
att2=Attribute Chart(
  X( :Kappa Parts ),
nw=new window("combined",
      vlb=v list box()
vlb<<append(report(att1)["Effectiveness"]);
vlb<<append(report(att1)["Conformance Report"]);
report(att2)["Effectiveness"]<<set title("Effectiveness 2");
vlb<<append(report(att1)["Effectiveness 2"]);
aravindan880
Hi nelson
I basically want to extract the effectivenss report from chart 1 and chart 2 and display it in one datatable or a summary
I want to extract the Effectiveness report , conformance report from chart 1, and Kappa effectiveness report from chart 2 and form a summary table
just to show the results summary only. this will be used for our report.
      Y( :Part ),
      X( :Kappa Parts ),
New Window( "test",
      tb1 = Table Box(
      tb2 = Table Box(
aravindan880
Thanks Jim
The script works like fine. It was a great help!!
