sanqub
How to combine/recode two columns?
I want to combine 2 columns. Suppose in sample library, big class example.
I want a new column which is combination of two columns "sex" and "age". The resulting column should have rows in form F12, M12 etc.
I tried with to combine columns using utility>combine but it gives error.
Thanks for your help
Re: How to combine/recode two columns?
Have you tried selecting both columns, right-clicking on the column name and selecting New Formula Column>Character > Concatenate?
ron_horne
try this.
dt << New Column( "Column", Character, Nominal, Formula( :sex || Char( :age ) ) );
i think the concatenate function only takes characters.
best,
ron
sanqub
Thank You.
ron_horne
try this.
best,
ron
sanqub
Hi Ron,
Thanks for the script. Even I think concatenate function just takes characters.
Santosh
ezorlo
hi i get an error on the snippet of code "<<"
Are you running the exact copy of the code below?
If not, can you include the exact JSL you are using.
