yetebreo
How to change row legend colors using JSL
Hi I am currently working on a script but I am stuck with one requirement that is to put specific colors for a specific row legend.
For example I have:
LEGENDNAME_OO
LEGENDNAME_PP
LEGENDNAME_QQ
I want to color legend with _OO suffix with red _PP with blue and _QQ with green
Thanks
uday_guntupalli
Level VIII
Re: How to change row legend colors using JSL
Hello ,
dt << Color by Column( :Age );
Wait( 2 );
dt << Color Rows by Row State;
I think you can further customize this  to match your needs
Best
uday
Best
Uday
It's depend of graph you are using.
For Overlay Plot, you can add Connect Color option to define colors options.
Overlay Plot(
  Y( :AA, :BB, :CC ),
  Connect Thru Missing( 1 ),
  :AA(
  Connect Color( 38 ),
  Line Width( "Thin" )
  :BB(
  Connect Color( 54 ),
  :CC( Connect Color( 71 ),
      Line Width( "Thin" ) ));
Guillaume
uday_guntupalli
Level VIII
Hello ,
Wait( 2 );
Best
uday
Best
Uday
yetebreo
Here is the code I am using
open("C:\Users\krash_tpd_cnt_char.csv");
Bivariate(
    Y(  :VALUE ),
    X(  :TEMP  ),
    By(  :VCC  ),
        Dispatch({},"1",ScaleBox,{
            ,Show Major Grid( 1 )
        Dispatch({},"2",ScaleBox,{
        Dispatch( {}, "Bivar Plot", FrameBox,
            {Row Legend(
                WAFER ,
                Color( 1 ),
                Color Theme( "JMP Default" )
this is what is being generated
but i want *-TT to be green, FF to be red then SS as is (blue)
Try changing the value ordering in the source column so that FF is first and -TT is second. I realize this is not a JSL solution, but it may get you where you want to be.
yetebreo
I am not sure how to change the ordering since these names could be anything only that it ends with TT FF and SS.
I hop somebody can help
You can do a script similar to this one to order value.
This script is not "perfect" but seems to be okay
dt = CurrentDataTable();
col = Column("VCC");
list = {};
ulist = {};
listTT = {};
listSS = {};
listFF = {};
/* Add data from VCC into a list */
For (i=1, i<=Nrows(dt),i++,
     InsertInto (list,col)
/* Create a unique list */
For (i=1,i<=Nitems(list),i++,
  If (Nrows(Loc(ulist,list)) == 0,
  InsertInto (ulist,list)
/* Create 3 lists contains pattern */
For (i=1,i<=Nitems(ulist),i++,
    if (contains(ulist,"TT") > 0,
    InsertInto (listTT,ulist)
    if (contains(ulist,"SS") > 0,
    InsertInto (listSS,ulist)
    if (contains(ulist,"FF") > 0,
    InsertInto (listFF,ulist)
/* Create the final list to have color order*/
list = {};
InsertInto(list,listFF);
InsertInto(list,listTT);
InsertInto(list,listSS);
/* Put Value ordering property */
col << Set Property("Value Ordering",list);
/* Then make your analysis */
Guillaume
