samir
How to calculate slope and intercept
I am facing 2 issues when trying tocalculate Slope and Intercept values:
  1. I did not find an easy way to get the Slope and intercept except the use of "Bivariate + fit line"
  2. Using the Bivariatein a loop seems to result in a slow execution of the code: I think that creating a table and the associated fit lile  several times is very slow
My question: is there a way to get the slope and intercept without using the bivariate to get faster ?
Here is the code I use in a loop to extract the slopes and intercepts:
biv1 = Bivariate( Y( MyTab:X ), X( MyTab:Y ), Fit Line( {Line Color( "Red" )} ) );
	colBox = Report( biv1 )[Number Col Box( 7 )];
	beta = colBox << GetAsMatrix;
	My_Slope = beta[2];   // slope
	My_Intercept = beta[1];   // intercept
	Close( MyTab, nosave );
Thanks.
ron_horne
Re: How to calculate slope and intercept
for starters, have a look at this option:
http://www.pega-analytics.co.uk/blog/linear-regression-matrix-form/
it is a solution offered by David Burnham in his blog. using matrix calculations he achieves high speeds for calculating the regression coefficients.
best,
ron
ian_jmp
Rather than having a loop, you could also consider making a big table with a 'By' variable, sticking with the Bivariate platform, then using 'Make Combined Data Table'. I expect the matrix approach will be faster, though.
ron_horne
best,
ron
samir
Thanks Ron,
That's what I was looking for: I will implement and test the spead :)
ian_jmp
RyMcQeN
Hi Ian,
I have followed your approach using the 'By' variable and sticking with the bivariate platform. I am not sure of the correct syntax for 'Make Combined Data Table' to work for multiple Fit Lines.  Can you help?
kXPlot = dt << Bivariate( Y( :LMS_dX ), X( :X_Nominal ), By(Column(::bcol)), Fit Line());
kXPlotDT = kXPlot < ???
Thank you,
Ry
RyMcQeN
I figured it out.
kXPlotDT = Report( kXPlot )["Parameter Estimates"][Table Box(1)] << Make Combined Data Table;
Regards,
Ry
