manphoolfageria
How to analyze the weather pattern data?
I wanted to know whether due to climate change, the precipitation in the last 16 years (2004 to 2019) had changed from the previous 15 years (1989 to 2003). Our hypothesis is that the weather patterns has changed and precipitation in the last 16 years had increased.
Here is the annual average data for different years.
Year
Precipitation (mm)
1989
384
1990
446
1991
471
1992
491
1993
507
1994
494
1995
356
1996
515
1997
438
1998
651
1999
487
2000
358
2001
353
2002
365
2003
396
2004
427
2005
551
2006
390
2007
298
2008
554
2009
451
2010
428
2011
571
2012
448
2013
818
2014
514
2015
654
2016
498
2017
429
2018
411
2019
529
I run this data using JMP after representing previous 15 years by X and last 16 years by Y. see below.
I performed permutation test. See below:
Results show that 91 per cent time I could say that the precipitation increased in the last 16 years (2004 to 2020) than previous 15 years (1989 to 2003).
My questions are as follows:
  • Is the analysis correct?
  • Should permutation performed with or without replacement?
  • Is there any other method, which can give us better results for this kind of analysis for example “the linear trend model?”
Other questions:
When a frequency data ranges from 0 to 30 and there are so many zeros in data, should the data be transformed?  Like taking the square root of each number, taking logarithm of each number (+.5) before fitting a “regression test” or “permutation test”?
Phil_Kay
Re: How to analyze the weather pattern data?
I don't know anything much about permutation analysis so I can't answer those questions.
But there are other things you could do.
Start with simple plots of the data...
...there does not appear to be a big change between these periods.
I have attached a jmp data table with your data including scripts for this plot and Fit Y by X analysis (again, no evidence for a difference between these periods).
I also used Lasso in Generalized Regression for change points analysis (JMP Pro only). This suggested a change point between 2010-2011. @clay_barker  has shown how to do this kind of thing before: https://community.jmp.com/t5/JMP-Blog/Did-LeBron-James-step-up-his-game-in-the-playoffs/ba-p/30609
I hope this helps.
Phil
