Talchaim-Damri
How to analyze pairs of parameters in one variable
Hi! I will try to explain my problem again.
I have two columns. One with Systems ID,
And second with Parts.
I would like to find if pair parts exist. Mean, I would like to build a list or table with all the possible pair, and and the amount of presence of each pair.
Presence means: two of the parts presence in the same systems
Georg
Re: How to analyze pairs of parameters in one variou
Did you try to use -->table --> summary grouping by Part or tablulate?
Thats a very easy way to see, if one parts has several ID's. Also you can try rows --> row selection --> select duplicate rows for col Part, that will select the Parts that are twice and more in the table.
See also JMP online help for this. The question also is how you want to perform (Script, Formula, GUI ...) and it would be very helpful, if you could provide an example and what exactly you expect to see.
Georg
Talchaim-Damri
Hi, thanks for your answer.
yes, I tried this, but it is not what I looking for.
I will try to give an example.
lets say this is the data:
systempart
1A
1B
1C
1A
1D
2B
2E
2G
2F
3A
3B
3F
so the results that I look for is
 ABCDEFG
AX210010
B X10111
C  X1000
D   X100
E    X11
F     X1
G      X
I'll explain.
There is a pair A-B in system 1 and system 3 - so rank 2
A-C are unique to system 1 - ranked as 1
The pair A-D doesn't exist at all - rank 0
hope I more clear now
Jasean
If I understand your example, I believe you want to subset your table by system.  Then join each subset table to itself using a Cartesian Join.  This will give you 3 tables that each contains 2 columns.  Each table represents all possible pairings of parts in each system.  In all three tables, name the columns the same.  For example, "First" and "Second".  Next, concatenate the 3 tables together.  You can then tabulate the final concatenated table to get the counts you want.  Below are the steps reiterated with pictures.  Note, however, that the result is not the same as you posted for the example.  For example, you point out that the pair A-D doesn't exist at all, but I think it does exist in system 1.  Correct me if I misunderstand.  Also, your example table has part A listed in system 1 twice.  I assumed that was a mistake and deleted the replicate.  If that is a bad assumption, how do you want to handle replicates?
Step 1:  Subset by system to get 3 tables.
    · Choose Tables -> Subset, check Subset by and select the system column:
   · JMP will give you 3 new tables:
Step 2: Cartesian Join each subset table to itself and rename columns to be the same in each table
   · For each subset table, make a copy of the table to join back to itself.  Choose Table -> Subset.  Then with All Rows and All Columns selected, click OK.
   · Next join the 2 identical tables.  From the menu of one table choose Table -> Join.  Then select the other identical table and choose Cartesian Join in the Matching Specification drop down box.  Click OK.  When the new table is created, you can close the 2 tables you just joined, you won't need those anymore.
Repeat this step for each of the 3 system tables to get the 3 tables of possible pairs within each system.  Don't forget to rename the columns in each table so when you later concatenate them, the columns will stack appropriately.
Step 3: Concatenate the 3 tables together and tabulate one column against the other.
   · Choose Tables -> Concatenate.  Then add the 3 tables into the "Data Tables to be Concatenated" box.  Click OK.
   · Finally, from the table just created, choose Analyze -> Tabulate and drag the two columns into the drop zones for Rows and Columns to get the tabulation shown below.
Talchaim-Damri
Hi Thank!.
1. Yes, systems 1 include pair A-D. My mistake :hushed_face:
2.. If just one duplicate (A or D) occurs - ignore it. If both duplicate - I would like to count two copies.
3. This method look good, but I have dozens of systems and dozens of tools, Maybe there other options?
thanks again 🙏🏼
Talchaim
