See how to use to use Text Explorer to glean valuable information from text data at April 25 webinar.
How to adjust individual Y axis
Alwyn
How to adjust Y axis scale separately for each group in graph builder
Re: How to adjust individual Y axis
You will need to use
     Tables=>Split
to change the 4 groups into 4 columns.  Then you can drag each of the columns to the Y drop zone and the axes will be independent of each other.
10 REPLIES 10
     Tables=>Split
Alwyn
I tried and now the Y axis value disappeared
An example:
Big Class data table
Tables=>Split
The split table
Graph Builder
Drag Height F to the Y drop area
Drag Height M to the Y drop area, but at the bottom of the Y axis area
Drag the Age column to the X drop area
The 2 Y axes are independently settable
ndowidar
Hi txnelson,
 I have a similar scenario where I'm unable to use the Split table feature to scale the Y-axis.
 I'd like to make a graph similar to this one below but have the Y-axis scaled for the different samples. My original data has different names so the samples are ordered differently than this graph example, so I need to figure a way to scale them.
 Thanks for your help!
If you have JMP18, you can use Page and then change how many items per row
ndowidar
Thank you so much for that! II do have JMP18 but I'm not familiar with that Page function. How do I find it?
It is a feature which isn't well known (in my opinion). After you have your column for Page (bottom right zone), right click on the Page zone, select Levels per Row and pick whatever fits your need
You also have few options which affect the axis in graph builder's red triangle menu to replicate / lock specific axis
ndowidar
I still haven't been able to figure out that Page feature yet. Can you elaborate a little using how you did that? All I've managed to find was this & that still hasn't worked for me. I guess this isn't the "Page" feature you suggested since it's about how many graphs you want to show in a wrap.
Level XII
since Jmp18, Page provides all the options of wrap:
Graph Builder - align 'pages' next to each other or as grid
The benefit of page vs. wrap:
the user can decide if axis ranges are linked or not linked.
