AT
AT
How to add a data table to web report?
I used the following example of create a project:
project = New Project();
project << Run Script(
dt << Run Script( "Bivariate" );
dt << Run Script( "Distribution" );
Now when I use publish, I get the web report with Distribution and Bivariate plot. How do I add data table as well? Thanks for your help.
13 REPLIES 13
AT
AT
Re: How to add a data table to web report?
Hi Jeff,
Thanks for the note. The number of rows are about 4000. I was able to create a dashboard and no issue with number of rows. Only when you want to create report out of projects you run into trouble. Thanks for all your help.
anne_sa
I also would like to add a data table in a web report but some of the cells are colored. Unfortunately, when I publish the journal of the table, the colors are lost. Is there a way do keep the table not truncated and with the colors?
Thanks for your help!
I have been successful in doing this by creating a picture object of the data table, rather than the actual data table
anne_sa
It works like a charm! Thank you very much @txnelson
