lala
How to add JSL to "Big Class.jmp" graphics using Hover Labels?
Start with the following JSL to generate the graph.
How to add JSL through Hover Labels to get cell name data Get "Big Class Families" file corresponding name data?
p1 = dt << Graph Builder(
	Variables( X( :weight ), Y( :height ), Group X( :age ), Color( :sex ) ),
	Elements( Bar( X, Y, Legend( 5 ), Response Axis( "X" ) ) )
8 REPLIES 8
lala
回复: How to add JSL to "Big Class.jmp" graphics using Hover Labels?
  • Need to add another JSL. For example:
Include("D:\test.jsl");
test.jsl:
dt = open("$sample_data/big class families.jmp","invisible");
overlay2 = dt:picture[1];// How do I get the name parameter that the cursor points to?
close(dt,nosave);
New Window("",V List Box(overlay2 ));
I suggest reading through JMP Help page regarding Hover labels Hover Labels (jmp.com).
lala
Thanks Experts!
I do need to add a script to Hover Labels.
Still not sure how to proceed?
lala
I will simply imitate,
Take this
Copy and paste it into the script of the hover TAB.
The image also pops up, but the correct name parameters are not correctly obtained.
Still don't know how to fix it.
Hope to get expert help.Thank you very much!
lala
I just paste in age =12, other ages don't work.How can all ages work?
Hold Ctrl when you right click and paste the graphlet. Each of the frameboxes have separate graphlets
Graph Builder(
	Variables(X(:height), Y(:weight), Group X(:age)),
	Elements(Points(X, Y, Legend(5)), Smoother(X, Y, Legend(6))),
		Dispatch({}, "Graph Builder", FrameBox, {Set Graphlet(Picture(Distribution(Nominal Distribution(Column(:age)))))}),
		Dispatch({}, "Graph Builder", FrameBox(2), {Set Graphlet(Picture(Distribution(Nominal Distribution(Column(:age)))))}),
		Dispatch({}, "Graph Builder", FrameBox(3), {Set Graphlet(Picture(Distribution(Nominal Distribution(Column(:age)))))}),
		Dispatch({}, "Graph Builder", FrameBox(4), {Set Graphlet(Picture(Distribution(Nominal Distribution(Column(:age)))))}),
		Dispatch({}, "Graph Builder", FrameBox(5), {Set Graphlet(Picture(Distribution(Nominal Distribution(Column(:age)))))}),
		Dispatch({}, "Graph Builder", FrameBox(6), {Set Graphlet(Picture(Distribution(Nominal Distribution(Column(:age)))))})
lala
Thanks Experts!
I follow the sample files in the index combined with your tips.This can automatically implement each age plus script.
But the question that remains to be solved is how to use this test.jsl to automatically get the name parameters of the various locations to which the cursor is pointing?
gb = dt << Graph Builder(
frame=(gb<<report)[FrameBox(1)];frame<<Set Graphlet(Picture(loader=Include("D:\test.jsl"); hlp=loader:lazyLoad("hllPresets"); hlp:launchPie();),Title("Pie Preset"),Reapply(1));
frame=(gb<<report)[FrameBox(2)];frame<<Set Graphlet(Picture(loader=Include("D:\test.jsl"); hlp=loader:lazyLoad("hllPresets"); hlp:launchPie();),Title("Pie Preset"),Reapply(1));
frame=(gb<<report)[FrameBox(3)];frame<<Set Graphlet(Picture(loader=Include("D:\test.jsl"); hlp=loader:lazyLoad("hllPresets"); hlp:launchPie();),Title("Pie Preset"),Reapply(1));
frame=(gb<<report)[FrameBox(4)];frame<<Set Graphlet(Picture(loader=Include("D:\test.jsl"); hlp=loader:lazyLoad("hllPresets"); hlp:launchPie();),Title("Pie Preset"),Reapply(1));
frame=(gb<<report)[FrameBox(5)];frame<<Set Graphlet(Picture(loader=Include("D:\test.jsl"); hlp=loader:lazyLoad("hllPresets"); hlp:launchPie();),Title("Pie Preset"),Reapply(1));
frame=(gb<<report)[FrameBox(6)];frame<<Set Graphlet(Picture(loader=Include("D:\test.jsl"); hlp=loader:lazyLoad("hllPresets"); hlp:launchPie();),Title("Pie Preset"),Reapply(1));
D:\test.jsl
d9 = open("$sample_data/big class families.jmp","invisible");
overlay2 = d9:picture[1];// How do I get the name parameter that the cursor points to???
close(d9,nosave);
nw=New Window("",V List Box(overlay2 ));
Wait(3);nw<<Close Window;
There are a lot of different variables you have access to in hover label execution context, see Scripting Guide > Scripting Graphs > Hover Labels > Work with the Hover Label Execution Context
