TimCarrWPI
How to Model Heteroscedastic Data with Linear Relationship Between Standard Error Magnitude and Predicted Value
I've collected data measuring the 'adhesion strength' of a 3D printed part to a plastic substrate as a function of several printing parameters. I have limited terms in my model (compared to a full 2nd order response surface design), as these are the terms found significant in a screening experiment.
When I model my data with standard least squares, my residual by predicted plot shows a clear expanding bell trend. However, when I divide the residuals by the predicted value, I get a very well-behaved set of residuals. I believe this implies that I can model standard error as a linear function of the predicted adhesion strength, but I'm not sure how to implement this.
Loglinear variance modeling might work, but it also calls for model terms for the variance when I think all I want to do is use the expected value of the mean. I've been suggested weighted least squares by Google results, but this doesn't look like something that's default implemented in JMP. What does the community suggest here? I've attached my data table.
Thank you,
Tim
0 REPLIES 0
