SabinaS
Spider graph
Hi All, I'm a new user of this software. I have the version 18.0. Is it possible to build a spider plot? Many thanks!
9 REPLIES 9
Re: Spider graph
There is at least Spider Plot Add-in . I suggest you read the comments for it (it isn't being developed anymore)
ALISIDDIQUI
Re: Spider graph
Hello
How can I have access to this add in please? Its saying I dont have enough privilege to access this link
Thanks
Re: Spider graph
JMP add-ins are now found from JMP Marketplace and it seems like this add-in hasn't been re-added to marketplace. @scott_allen
ALISIDDIQUI
Re: Spider graph
Hi jthi
Still cant find such add-in in the JMP Marketplace... please send a specific link to the location where it is accessible. Thanks
A
Re: Spider graph
Spider Plot aka Radar Chart will be added in the next version of JMP. If this capability is important for you, you can join the Early Adopter program to try it out. If you do so, please keep in mind this is pre-production software, with the expectation that users are willing to test and provide feedback on new features.
ALISIDDIQUI
Re: Spider graph
Still cant find such option in the JMP Trial version neither in jmp-19...
markschahl
Re: Spider graph
JMP makes beautiful parallel plots, much better visual than radar/spider charts IMHO. Some background. Give parallel plots a try!
ALISIDDIQUI
Re: Spider graph
Thanks a lot Mark
However, this is not a solution. It is one thing to say: "The capability is not available in this software" and another to say "Use this other option instead, which doesn't fulfil the initial requirement at all, and from a different software"...
Thanks but no thanks...
It will be great if someone could point to the proper solution for plotting radar-plots, or simply tell that this is not existing the software. Much appreciate a little bit of proper support. Thanks
Re: Spider graph
Sorry if my previous comment was unclear. Spider Plots are a new feature within Graph Builder, not available in older versions like JMP 18. To create Spider Plots, you need JMP 2027, which is accessible at the following link for any authorized JMP user: Early Adopter | JMP
