To complete the suggestion from @shampton82, you can compare the performances of different models using the platfrom Model Comparison. This way, no matter how or with which estimation methods the models have been built, you can compare them with the same metrics (example here with standard least squares, standard least squares with box-cox transformation, loglinear variance model and Generalized regression model with Normal Pruned Forward estimation method):
As you already pointed out, if you're only interested about the mean response, these models are very close to each others in terms of performances. In this platform, you can use the option "Model averaging" to see if this model averaging can have better performances than individual models (but here it's not the case):
You can also compare the magnitude of the residuals between the models (but again, they are very close between models).
When using the Profiler in this platform, you can also use the option Assess Variable Importance (Independant uniform Inputs as your data comes from a DOE without any specific constraints) to better compare how the different models evaluate the importance of the factors. You can right-click on the results provided, Make into Combined datatable, and then use Graph Builder to better visualize the results with a heatmap for example:
Again, no matter the type of model and estimation method, all the models seem to find the same root causes and impact of your factors on the response. If you are only interested about the mean response, then the model choice can be quite open. If you're also interested about the variance, loglinear variance model is in my opinion the best option to model both mean responsa and variance response.
Please find attached the completed file with two added scripts based on what has been shown in this answer.
Victor GUILLER
