Neo
Neo
How to (1) change default color in AxisBox and (2) add reference line in only one Y-axis variable in grouped Y plots?
In the chart generated by the script below I would like to change the color of the lines indicated by the red arrows ("the separator lines") to purple. Also I would like to add a horizontal reference line only for the lowest y-axis variable (in this case PNP1).
How to do these via JSL?
(Note in my actual case the y-axis data is not from a column unlike in this example case)
dt = Open( "$SAMPLE_DATA/Semiconductor Capability.jmp" );
Graph Builder(
	Size( 960, 695 ),
	Variables(
		X( :SITE ),
		X( :lot_id, Position( 1 ) ),
		X( :wafer, Position( 1 ) ),
		Y( :NPN1 ),
		Y( :NPN2 ),
		Y( :PNP3 ),
		Y( :PNP1 )
	Elements( Position( 1, 1 ), Points( X( 1 ), X( 2 ), X( 3 ), Y, Legend( 44 ) ) ),
	Elements( Position( 1, 2 ), Points( X( 1 ), X( 2 ), X( 3 ), Y, Legend( 43 ) ) ),
	Elements( Position( 1, 3 ), Points( X( 1 ), X( 2 ), X( 3 ), Y, Legend( 38 ) ) ),
	Elements( Position( 1, 4 ), Points( X( 1 ), X( 2 ), X( 3 ), Y, Legend( 40 ) ) ),
		Dispatch(
			"SITE",
			ScaleBox,
			{Label Row( 3, {Major Grid Line Color( 8 ), Show Major Grid( 1 )} )}
15 REPLIES 15
Level XIII
Re: How to (1) change default color in AxisBox and (2) add reference line in only one Y-axis variable in grouped Y plots?
the first time, you can run  getTestStage(1) manually.
Please note that with the Data Filter there are 1-3 FrameBoxes in the GraphBuilder (most of the time, just 1?). So either you determine which FB to send the message to - or just select one TestStage and always send the command to Framebox 1.
Level XIII
By the way - there is a new feature in Jmp17:
add dynamic reference lines based on statistics values
Graph Builder(
	Y Group Edge( "Left" ),
	Summary Statistic( "Median" ),
	Variables( X( :PartNumber ), Y( :Median ), Group Y( :TestStage ) ),
	Elements(
		Points( X, Y, Legend( 33 ) ),
		Smoother( X, Y, Legend( 34 ) ),
		Caption Box(
			X,
			Y,
			Location( "Axis Reference Line" )
	Local Data Filter(
		Conditional,
		Add Filter( columns( :TestStage ), Where( :TestStage == 1 ) )
SDF1
Hi @Neo ,
  That's a very cool idea that @hogi has in regards to using a Filter Change Handler. I hadn't thought of that. I modified your above code to fix the two issues you were having. The script will now create the first graph with the reference line, and then update each graph accordingly, even when choosing more than one data filter. Does this solve the issue?
//this creates a string list of the column names
ColNamesList = dt << Get Column Names( "string" );
//This tests if the there exist a :Mean Column. If not, it runs a summary to generate this data, updates the main table with the means and then deletes a column and closes out the summary table.
If( Contains( ColNamesList, "Mean" ) == 0,
	dtMeans = dt << Summary(
		Group( :TestParameter ),
		Mean( :Median ),
		Freq( "None" ),
		Weight( "None" ),
		statistics column name format( "stat" ),
		Link to original data table( 0 ),
		output table name( "MeanStats" )
	dt << Update( With( dtMeans ), Match Columns( :TestParameter = :TestParameter ) );
	dt << Delete Columns( :N Rows );
	Close( dtMeans, NoSave );
//this makes the original graph with the reference line of the first row in column :Mean
gb = dt << Graph Builder(
	Elements( Points( X, Y, Legend( 33 ) ), Smoother( X, Y, Legend( 34 ) ) ),
	Dispatch(
		"Graph Builder",
		FrameBox( N Items( testStateFiltered ) ),
		{Add Graphics Script(
			2,
			Description( "" ),
			Pen Color( "red" );
			Line Style( "dashed" );
			Pen Size( 0.25 );
			Y Function( Eval( :Mean[1] ), x );
	Local Data Filter( Conditional, Add Filter( columns( :TestStage ), Where( :TestStage == 1 ) ) )//no {} around the 1 here.
ldf = Current Report()["Local Data Filter"] << get scriptable object;
getTestStage = Function( {this}, //print (this);
	testStateFiltered = Associative Array( :TestStage[ldf << get filtered rows] ) << get keys;
	//this finds which row to grab the mean from
	mrows = dt << Get Rows where( :TestStage == testStateFiltered[1] );
	//this defines the mean to Eval() in the Y Function()
	gbmean = :Mean[mrows[1]];
	If( N Items( testStateFiltered ) == 1, //only does this if only one data filter is selected
		gbreport = gb << Report; //makes a report reference for the graph builder
		fb = gbreport[GraphBuilderComponentBox( 17 )];//accesses the frame to remove the script from
		fb << Remove Graphics Script( 1 );//removes most recent script from the frame
	gb << SendToReport(
		Dispatch(
			"Graph Builder",
				2,
				Description( "" ),
				Pen Color( "red" );
				Pen Size( 0.25 );
				Y Function( Eval( GBMean ), x );
	Show( N Items( testStateFiltered ) );
	Print( testStateFiltered );
rs = ldf << Make Filter Change Handler( getTestStage() );
Hope this helps!,
DS
Neo
Neo
@SDF1 @hogi
The data table I shared was a quickly put together as an example. I should have mentioned that I cannot use LSL/USL or any other number in this table for generating the reference line.
Any how, the following has worked for me.
  • Calling getTestStage(1) before the Make Filter Change Handler call.
  • Adding RemoveGraphicsScript (N) with appropriate handles inside getTestStage function where N is the FrameBox number obtained from last selected TestStage Framebox number generated when the TestStage filter is changed.
I will settle for this now. However, there is one remaining issue. If select one TestStage, then a second one and then a third one, everything works as expected, but if I go back from 3 selections back to one, my script does not work as expected.
When I get a chance, I will post a representative data set with the script explaining the issue.
Neo
Neo
@SDF1
This adds reference lines to all the subplots which is not what I want.
Level XIII
you could calculate the median directly from the values - and the LSL/USL could be read from the data table:
Graph Builder(
myFB = Current Report()[FrameBox( 3 )];
myFB << Add Graphics Script(
	2,
	Description( "" ),
	mySeg = myFB << Find Seg( Marker Seg( 1 ) );
	value = Median( mySeg << Get Y Values );
	Pen Color( "red" );
	Pen Size( 3 );
	H Line( value );
	Pen Color( "blue" );
	Pen Size( 1 );
	myRow = (Current Data Table() << get rows where( :TestStage == 3 ))[1];
	myUSL = :USL[myRow];
	myLSL = :LSL[myRow];
	H Line( myUSL );
	H Line( myLSL );
