Which line is the problem?
At the moment, there is just a single horizontal line in the lowest plot.
If you have to hide parts of reference lines, you can use the fact that every subplot has it's own customization settings, so you can add some rectangles and put them in front of the reference line.
[alternatively, you could also directly use the customization script to add a line segment.]
dt = Open( "$SAMPLE_DATA/Semiconductor Capability.jmp" );
dt << Graph Builder(
Show Title( 0 ),
Show X Axis Title( 0 ),
Variables(
X( :SITE ),
X( :lot_id, Position( 1 ) ),
X( :wafer, Position( 1 ) ),
Y( :NPN1 ),
Y( :NPN2 ),
Y( :PNP3 ),
Y( :PNP1 )
Elements( Position( 1, 1 ), Points( X( 1 ), X( 2 ), X( 3 ), Y, Legend( 44 ) ) ),
Elements( Position( 1, 2 ), Points( X( 1 ), X( 2 ), X( 3 ), Y, Legend( 43 ) ) ),
Elements( Position( 1, 3 ), Points( X( 1 ), X( 2 ), X( 3 ), Y, Legend( 38 ) ) ),
Elements( Position( 1, 4 ), Points( X( 1 ), X( 2 ), X( 3 ), Y, Legend( 40 ) ) ),
Dispatch( {}, "SITE", ScaleBox,
{Add Ref Line( 714.422378299564, "Solid", "Red", "", 4 ),
Label Row(
1,
{Lower Frame( 1 ), Row Title Side( "Start" ), Show Major Grid( 0 ),
Tick Mark Style( "Long Divider" )}
), Label Row(
2,
), Label Row(
3,
{Line Color( "Purple" ), Line Width( 3 ), Lower Frame( 1 ),
Major Grid Line Color( "Purple" ), Row Title Side( "Start" ),
Dispatch( {}, "PNP3", ScaleBox, {Add Ref Line( 135, "Solid", "Red", "", 3 )} ),
Dispatch( {}, "PNP1", ScaleBox, {Add Ref Line( 300, "Solid", "Black", "", 5 )} ),
Dispatch( {}, "400", ScaleBox,
{Legend Model( 38, Properties( 0, {Transparency( 0.5 )}, Item ID( "PNP3", 1 ) ) )}
Dispatch( {}, "Graph Builder", FrameBox,
{Grid Line Order( 2 ), Reference Line Order( 1 ),
Add Graphics Script(
2,
Description( "" ),
Fill Color( white );
Rect( -10000, 10000, 10000, -10000, 1 );
Dispatch( {}, "Graph Builder", FrameBox( 2 ),
2,
Description( "" ),
Dispatch( {}, "Graph Builder", FrameBox( 3 ),
2,
Description( "" ),
Rect( 290, 10000, 10000, -10000, 1 );
Dispatch( {}, "Graph Builder", FrameBox( 4 ), {Reference Line Order( 3 )} )
