  • Due to inclement weather, JMP support response times may be slower than usual during the week of January 26.
    To submit a request for support, please send email to support@jmp.com.
    We appreciate your patience at this time.
MathStatChem
How do you replace square brackets "[" "]" in a string with Regex?
I know that [ and ] are special characters in regular expressions, but I can't figure the right escape string to be able to treat them as a specific character in a pattern string.
What I want to do, as an example, is convert "[1 1 1]" to "1 1 1".
Re: How do you replace square brackets "[" "]" in a string with Regex?
maybe Regex issue with escaped characters
You are probably fighting JMP's escaping getting mixed up with regex escaping @paul_vezzetti .
JMP strings make a special case of \[ and ]\ anywhere in a JMP string to turn off JMP's escaping.
try \!\[ and just use a bare ] . Regex should not need to escape the ] unless it is in a [character class].
regex("[1 2 3]","\!\[(.*)]","\1")
"1 2 3"
\!\ is JMP's escape to make a literal backslash. Regex then sees the \[ and behaves as expected.
Alternatively, you could use the \[ ... ]\ , but it creates worse problems if you actually need ]\ in the regex and seems less clear:
regex("[1 2 3]","\[\[(.*)]]\","\1")
I hope JMP gets a regex-quoted string to solve this double escaping issue.
pmroz
For something that simple can't you just use substitute?
a = "[1 1 1]";
b = substitute(a, "[", "", "]", "");
show(b);
"1 1 1"
"1 2 3"
pmroz
a = "[1 1 1]";
show(b);
"1 1 1"
