Bass_Masri
How do you display all data values on the chart permanently?
You can display a value permanently. You simply Label the variable that you are interested in, select the rows and it will display…
Bass Masri
BSc.(Math) MStat.
Byron_JMP
Re: How do you display all data values on the chart permanently?
Two steps.
1. Turn on the Label state for the column with the data or label your want to display.
its ok to use multiple columns, the label values will be in the order of the columns.
2. Select all the rows (Edit select all) Turn on the Label row state of all the rows.
