I'm performing a Dunnett's Test using a control group. When I run the Dunnett's test I'm prompoted to select the control group, I select the control group and the graph and statistics are updated, no issues so far. The problem is when I'd like to change the control group, how do you do this without having to re-run the entire Fit YbyX analysis?
When I remove the Dunnett's test and then turn it back on I'm not prompted to select the control group again, JMP automatically selects the group which was selected the first time the analysis was run but I'd like to select a different group.
I'm using JMP 13. The information I'm seeking is not in the help section or books.
