取消
显示结果
显示  仅  | 搜索替代
您的意思是:
选择语言 隐藏翻译栏
Jimbo
How do I unlock a column?
I have never used the lock feature and do not know how I got here.  How do I unlock a locked column?
1 个已接受解答
已接受的解答
Re: How do I unlock a column?
I am making the assumption that the data table you are having an issue with, is one that you created from the Summary Platform, or maybe from the Subset Platform.  In both cases, the Locking came from having the "Link to Original Data Table" selected.  You can remove the lock by either deleting the table, and rerunning the Summary or Subset with the "Link to Original Data Table" unchecked, or Save and close the data table, then reopen it, and go to the Column Info for the column in question, and unselecting the "Lock" check box.
在原帖中查看解决方案
7 条回复7
new_2_JMP
Hi
I am having this same problem. I exported data from a .csv file into .jmp and the column I am interested in is locked and I can not unlock it. I do not have any link to the original data as you mentioned above. It is just a .csv file that brought up into JMP for plotting
What do you mean by Summary Platform and Subset Platform?
Thanks
new_2_JMP
Jimbo
@new_2_JMP See attached.
The summary and subset screenshot area is attached.
I found my answer by right clicking on the problem column, selecting column info and unchecking the lock button.
new_2_JMP
Hi
Thanks a lot for your helps. A picture do worth a thousand lines. I did not know what he meant by Table Summary and table Subset. I got it now and it fixes my problems
Thanks again
new_2_JMP
Jimbo
@new_2_JMP  you are welcome!
owg
owg
I thought the fixes here didn't work but I found that with a formula column it's more complicated.  After saving, closing & re-opening, the column still would not unlock.  But I noticed that formula evaluation was suppressed.  Unchecking suppress evaluation made the the formula update using only the subset data.  This was much better than deleting my formulas!
ndowidar
I am having a similar problem. I would like to apply a new formula to a subset of the data in the column, but when I highlighted the rows that need to the new formula, the formula was changed to the entire data set. So I made a new column with the new formula to adjust it manually but the forumula is locked & not supressed, so I'm not sure what to do.
 Thanks for your help!
推荐文章
