tarpon17
How do I sum multiple columns using the formula window?
I have a table with 100 or more columns and would like to easily sum them in another column.  Best way to do so without making a formula A + B + C.....100 times
ms
Super User (Alumni) ms
Re: How do I sum multiple columns using the formula window?
If a dynamic formula is not crucial, the jsl script below should add a new static column with the row-wise sum of every numeric column in the data table.
dt = Current Data Table();
dt << New Column("sum", numeric, values(V Sum((dt << get as matrix)`)));
Jeff_Perkinson
You can also do this within the formula editor using the Sum() function.
Fill in the argument for the function by clicking on the first column that you want to sum, and then shift-click on the last.
-Jeff
-Jeff
ms
Jeff_Perkinson
-Jeff
-Jeff
