dbahr
How do I search for a specific column name for "process", sperate by a known "sample label" and a known "by"
Hi everyone,
I've tried to search before I asked. I'm learning and very very new with the JMP software, we are using version 10.
What I'm trying to do is make a script that will look in any given data table for specific column names and cast the columns into roles for a control graph IR.
In the control graph I want it to find the column and use it for the "process" portion. Then use sample labels that I can re-write over the code. Then I'd like to seperate the information in the column. I can do all this manually in programing a control chart. What I've been trying to find out for a while now is how to have it scripted so that it generates the control charts automatically, and saves them as a PNG every time.
I imagine it needs a For statement loop. But how do I have the script identify the columns to see if they match with what I"m looking for?
I've tried
dt << Get Column Names () but then if I use that there really isn't any way to store that list and say
For columns b-f make a control chart. Or at least that I'm aware of.
Any help on this would be very much appreciated
Thanks
Daniel
David_Burnham
Re: How do I search for a specific column name for "process", sperate by a known "sample label" and a known "by"
Get Column Names returns a list - here is an example of how you could use it:
lstColNames = dt << Get Column Names(string);
show(lstColNames);
If ( Contains(lstColNames,"height"),
      show("column height exists")
-Dave
