See how to use to use Text Explorer to glean valuable information from text data at April 25 webinar.
BHarris
How do I plot mathematical functions with JMP?
I realize that JMP isn't a mathematical function plotter, but suppose I have a function:  y=((v1+v2)*sin(v3+arcsine(v1/(v1+v2)))/sin(pi()-v3-arcsine(v1/(v1+v2))-v4/v1)-v1)
... and I'd like to plot it using Graph Builder.  Is there a convenient way to do this type of thing with JMP?  (preferably without resorting to JSL)
Seems like it would involve building a full-factorial matrix of inputs v1 thru v4, but it's not clear to me how to do that, even with the DOE FFD platform, especially if I'd like some of those variables to have hundreds of values, e.g., v1 to be 0 thru 5000 every 10.
Jeff_Perkinson
Re: How do I plot mathematical functions with JMP?
@BHarris wrote:
I understand -- I think I was mostly interested in knowing *how* to build the data table if I knew what levels I wanted for each of the inputs. Basically, is there an easy way to build a full-factorial-matrix data table given a min, increment, and max value for each variable?
Take a look at the Sequence() function (it's the Row functions in the Formula Editor),  and also Tables->Join, where you'll find a Cartesian join option.
Two data tables, one column each, Sequence() formulaTwo data tables, one column each, Sequence() formula
Join Dialog, Cartesian Join optionJoin Dialog, Cartesian Join option
Resulting data tableResulting data table
-Jeff
19 REPLIES 19
gzmorgan0
@BHarris,
The Nonlinear Model platform and the simulators work well for this. If I get time, I'll send an example.
Surface Plot can do this too. With NO data tables open, start surface plot from the menu, then set up like this
Choose the vN for two of the axes and set values for the other vNChoose the vN for two of the axes and set values for the other vN
Show Formulas, replace the default formula with your own formula, pick your axis variables, use the mouse to rotate and adjust the axes. I'm pretty sure your formula generates missing values for some vN values, and the surface is being interrupted by them.
stan_koprowski
@Craige_Hales,
Cool.  I did not know that.
I learn something new everyday.
cheers,
Stan
There's a little bit more, see Three JSL Easter Eggs
Triple Helix spinning in 3DTriple Helix spinning in 3D
BHarris
How did you get JMP to auto-rotate the Triple-Helix?
shift key with mouse drag or arrow keys. It saves the rotation angle/speed in the script and will come up already rotating.
ain't that the truth!
BHarris
I had no idea JMP would do this, pretty amazing! Reminds me of the old Graphing Calculator app on the PowerPC Mac.
I asked about Graph Builder because we need to end up with a family of line plots (X, Y, group X, group Y, overlay) that we can read values from.
But I'm going to share this with the other JMP users at my work, super cool. Thanks!
rc_hertzy
I still use Graphing Calculator (v 4.0) as still have access to Mac OS 10.12. GC is better for interactive presentations of 2D plots because of the larger size than, say, Nonlinear platform shows, and that you can quickly expand/contract the axes with CMD or OPT mouse clicks.
