BHarris
How do I make start/stop bar charts?
Suppose I have this data:
StepStartStop
mixer02
heater1112.3
injector144.5
mixer68
heater210.313
injector11212.5
heater11625.4
mixer1820
heater223.430
mixer2426
fan2445
mixer3040
... and I want to make this plot (just the bars):
Is that possible with GraphBuilder?  (note this image is a mockup with PowerPoint)
16 REPLIES 16
Victor_G
Re: How do I make start/stop bar charts?
Hi @BHarris,
I'm not able to reproduce directly what you present in powerpoint, but I may have something similar enough to what you intend to have :
Unlike your image, the different ranges are not completely aligned, as I need to have a unique identifier for each values range.
I think the bars could be enlarged for better readability.
You can have a look at the script in the attached datatable.
EDIT: Using a ID column with less levels, the bar graph looks better :
Both graph scritps are saved in the attached datatable.
Victor GUILLER
Level XIII
Nice approach : )
As an alternative to Overlay, one could also use the ID nested on the Y axis:
BHarris
Both of these options create a lot of whitespace because each on/off gets its own horizontal row, and there can be a lot of on/offs in my use-case.  The bar-plots have a red-triangle "overlap" setting that seems like it should work, but even at "Full" it doesn't seem to do anything, so I was hoping there might be a hidden option or a JSL approach that would keep the bars aligned vertically.
There are many JSL options for something like this. Set Marker Expr would most likely be the best if you can figure how that is used (it doesn't really have documentation). Here is my quick take using Set Marker Draw Expr, this can be made simpler using just one marker but having two lets user "select" the row from both ends
dt = New Table("Untitled 2",
	Add Rows(12),
	Compress File When Saved(1),
	New Column("Step",
		Character,
		"Nominal",
		Set Property("Value Colors", {"fan" = -15113984, "heater1" = -5682409, "heater2" = -40563, "injector1" = -29362, "mixer" = -13983232}),
		Set Values({"mixer", "heater1", "injector1", "mixer", "heater2", "injector1", "heater1", "mixer", "heater2", "mixer", "fan", "mixer"})
	New Column("Start",
		Numeric,
		"Continuous",
		Format("Best", 12),
		Set Values([0, 1, 4, 6, 10.300000000000001, 12, 16, 18, 23.399999999999999, 24, 24, 30])
	New Column("Stop",
		Numeric,
		"Continuous",
		Format("Best", 12),
		Set Values([2, 12.300000000000001, 4.5, 8, 13, 12.5, 25.399999999999999, 20, 30, 26, 45, 40])
dt << Color or Mark by Column(:Step, Color(1), Marker(0));
gb = dt << Graph Builder(Variables(X(:Start), X(:Stop, Position(1)), Y(:Step), Color(:Step)),
	Elements(Points(X(1), X(2), Y, Legend(7))),
		Dispatch({}, "400", ScaleBox,
			{Legend Model(
				7,
				Properties(0, {Marker("FilledSquare")}, Item ID("fan", 1)),
				Properties(1, {Marker("FilledSquare")}, Item ID("heater1", 1)),
				Properties(2, {Marker("FilledSquare")}, Item ID("heater2", 1)),
				Properties(3, {Marker("FilledSquare")}, Item ID("injector1", 1)),
				Properties(4, {Marker("FilledSquare")}, Item ID("mixer", 1))
		Dispatch({}, "400", LegendBox,
			{Legend Position({7, [0, 1, 2, 3, 4, -1, -1]})}
frame = Report(gb)[FrameBox(1)];
seg = (frame << FindSeg(Marker Seg(1)));
seg << Set Marker Draw Expr(
	Function({this seg, this row, x, y, size, row state},
		Fill Color(Color Of(Row State(this row)));
		Rect(x, y + 0.3, x + (:Stop[this row] - x) / 2 + 0.1, y - 0.3, 1)
seg = (frame << FindSeg(Marker Seg(2)));
		Rect(x - (x - :Start[this row]) / 2 - 0.1, y + 0.3, x, y - 0.3, 1)
There are also most likely options where you heavily modify your data to fit just graphing needs.
Level XIII
wow, this is amazing!
Maybe remove the "/2" and draw 2 overlapping rectangles. Then the bars stays stable even if start or stop is close to the edge or even outside of the graph.
(view in My Videos)
There are basically infinite amount of ways of doing this. Pick which best suits for needs (or create your own). Rect from start to end while utilizing average point allows easily using start/stop markers for example while adding extra "marker" to center for user to click.
Level XIII
Instead of
can Set Marker Draw Expr() also use the the color theme defined via the Color dropzone?
Is there a built-in function which does something like
w= current window() << get namespace;
// get the script - and from there the first color
gbscript = gb << get script;
vars = Extract Expr( gbscript, Variables( Wild List() ) );
w:colorCol = Try(
	Arg( Extract Expr( vars, Color( Wild() ) ), 1 ),
	Caption( "no color" );
	stop;
// use the legend server to gt the gradient settings
legend = gb << get legend server;
items = {};
For Each( {list}, legend << get legend items, Insert Into( items, list ) );
gradient = Filter Each( {item}, items, item << get Type == "Gradient" );
If( Not( N Items( gradient ) ),
	Caption( "no gradient" );
	Stop();
gradient = gradient[1];
// parse the gradient settings to create my own color interpolation function
settings = gradient << Get Gradient Settings;
colorTheme = settings["Color Theme"];
colors = If( Is List( colorTheme ),
	colorTheme[3],
	Get Color Theme Detail( colorTheme )[3]
colors = Matrix( Remove( colors, N Items( colors ) ) );
xs = ((1 :: N Items( colors[0, 1] )) - 1) / (N Items( colors[0, 1] ) - 1);
scale = settings["Scale Values"];
reverse = settings["Reverse Gradient"];
min = scale[If( reverse, 2, 1 )];
max = scale[If( reverse, 1, 2 )];
Eval(
	Eval Expr(
		w:col = Function( {x},
			x2 = (x - Expr( min )) / (Expr( max - min ));
			Eval List(
				{Interpolate( x2, xs, Expr( colors[0, 1] ) ), Interpolate( x2, xs, Expr( colors[0, 2] ) ),
				Interpolate( x2, xs, Expr( colors[0, 3] ) )}
Level XIII
It is interesting that "Size" is among the parameters which are transferred to
and that Color is not.
BHarris
The JSL rect-drawing approach does create the correct image, and I'm thrilled to learn how it works in JMP.  I'll need to play with that more.
What we lose, however, is the ability to click inside the bars to select the corresponding rows in the data table.  My dataset is also quite large (multi-million rows) and is divided into sets that are keyed by a 4th column that goes into the local filter.  This way we can look at any set of results quickly in the same window.  I know coding the JSL to update the bars whenever the Local Data Filter changes is possible, but it adds another layer of complexity.
I think I'll submit a wish list item to fix/update the "Bar Overlap" setting to allow the "ID" column to collapse the different rows into a single one when used as an overlay.
Impressive responses all around!  Thank you to all who have responded!
