Nita_Natchanok
How do I import .txt file with several rows of column header
How do I import .txt file with several rows of column header?
There is no selection in txt import window to select multiple rows as column header similar to Excel Import Wizard
So, what I did was.
Import text as JMP table.
Save the JMP table as xlsx. file
Import the xlsx. file by using Excel Import Wizard and specify how many rows we need for the column header
Is there any other way?
dT = current data table();
Directory = "$DESKTOP/";
dT_Name = dT << get Name();
XL_Name = Directory || dT_Name || ".xlsx";
dT <<  Save( XL_Name );
Close(dT);
Open(
	XL_Name,
	Worksheets( dT_Name ),
	Use for all sheets( 1 ),
	Concatenate Worksheets( 0 ),
	Worksheet Settings(
		1,
		Has Column Headers( 1 ),
		Number of Rows in Headers( 3 ),
		Headers Start on Row( 3 ),
		Data Starts on Row( 6 ),
		Data Starts on Column( 1 ),
		Data Ends on Row( 0 ),
		Data Ends on Column( 0 ),
		Replicated Spanned Rows( 1 ),
		Suppress Hidden Rows( 1 ),
		Suppress Hidden Columns( 1 ),
		Suppress Empty Columns( 1 ),
		Treat as Hierarchy( 0 ),
		Multiple Series Stack( 0 ),
		Import Cell Colors( 0 ),
		Limit Column Detect( 0 ),
Delete File(XL_Name);
Re: How do I import .txt file with several rows of column header
I think you might be able to do it with Multiple File Import (depending on your data). Change Settings and modify CSV import settings as needed
