Discovery Summit 2026: Early User Edition - September 23-24.Register. It's free.
See how to design an experiment, explore factor-response relationships, assess tradeoffs, and ID best settings. Register for Sep. 11 Mastering JMP.
This is a screen shot of my graph. why are there no no.s on the Y axis & what do the up arrows mean on the graph? the data is numeric & continuous. thanks
With the arrows you can swap the order of axis. You have parallel independent axis currently (most likely you have Auto, but then JMP determines this would be the best one).
