How do I get JMP to close pdf files that have been opened to extract information?
Since I am new to scripting, I just copied a script from a previous discussion (https://community.jmp.com/t5/Discussions/Batch-processing-files-to-extract-data-into-a-summary-table...) and slimmed it to the stuff I need - only the pdf file names.
Names Default to Here( 1 );
//point to file directory
path = Pick Directory( "Select Directory Containing Data Files" );
//Gets the list of files in the selected file folder
file_list = Files In Directory( path );
// Create beginnings of output data table
dtFinal = New Table( "Final", New Column( "File Name", Character ));
//i=0;open file
nfile_list = N Items( file_list );
For( i = 1, i <= nfile_list, i += 1,
	//Set Current Directory( dir_DirectoryPath );
	dt = Open( path || file_list[i], );
		// Add information to Final data table
	dtFinal << add rows( 1 );
	dtFinal:File Name[N Rows( dtFinal )] = file_list[i];
Unfortunately, I have about 750 pdf files which all open while running the script.
Does anybody know how to automatically close the pdf files?
Thanks a heap for your help
mmarchandTSI
Re: How do I get JMP to close pdf files that have been opened to extract information?
It doesn't look like there's any need to open those pdfs in the first place, since all your script is doing is putting a filename in each row of :File Name.
dtFinal = New Table( "Final", New Column( "File Name", Character ) );
//i=0;open file
	//dt = Open( path || file_list[i], );
But you could do it even quicker and more efficiently.
dtFinal = New Table( "Final", New Column( "File Name", Character, Set Values( Files In Directory( path ) ) ) );
Thank you so much for helping me on this issue.
Much simpler and exactly what I wanted.
Happy to be in this community.
Have a great day :)
