terapin
How do I extract excel filename from a user-selected file?
Folks,
I can't seem to figure out how to extract the original file name of an Excel workbook that a user selects.  After selecting the appropriate file as shown below, the actual file name I get is the worksheet name (sheet 1), not the original file name (test_data.xls). I'm ultimately trying to rename the originally selected excel file and need the file name, not the opened worksheet name, to accomplish this. Any ideas how I can accomplish this?
dt = Open(
  Pick File( "Select Excel File", "$dir_rawdata/", {"All Files|*"}, ),
  Worksheets( "1" ),
  Use for all sheets( 1 ),
  Concatenate Worksheets( 0 ),
  Worksheet Settings(
  1,
  Has Column Headers( 1 ),
  Number of Rows in Headers( 3 ),
  Headers Start on Row( 1 ),
  Data Starts on Row( 4 ),
  Data Starts on Column( 1 ),
  Data Ends on Row( 0 ),
  Data Ends on Column( 0 ),
  Replicated Spanned Rows( 1 ),
  Suppress Hidden Rows( 1 ),
  Suppress Hidden Columns( 1 ),
  Suppress Empty Columns( 1 ),
  Treat as Hierarchy( 0 )
fname.old = dt << Get Name;
anders_bankefor
Re: How do I extract excel filename
I've managed to extract excelfile name using the word() function:
for example:
Excelfile = pick file ("Select your CSV File(s)", "", {"JMP Files|csv", "All Files|*"}, 1, 0, "", "multiple" );
For ( [logic],
  SampName = Word( -1, Excelfile , "/" );
  ExcelName = Word( 1, SampName, "." );
  file contents = Load Text File( Excelfile );
//use the file cotents to phrase through your rows
the ExcelName will give you the name of your excelfile
cheers
terapin
Thanks folks for your suggestions,
I was playing around and realized I needed to define a data table from the file selected in the Pick File function: dt.select = Pick File( "Select Excel File", ...... Once I did that I was easily able to parse out the file name using the Word function.
MS, thanks for the clever way of extracting the file name from the Source property.  That was a really clever and learning about the use of -1 Word was very helpful.
anders_bankefor
for example:
For ( [logic],
cheers
ms
Super User (Alumni) ms
The file name is part of the "Source" script. I think this works (assuming POSIX path):
fname.old = Word(-1, Arg(dt << Get property("Source"), 1), "/");
terapin
anders_bankefor
Thats a good idea, it all depends on what your script should do. Personally I had the need of reading in several excel files at once, therefore I stored the files into a list and phrased them using for-loops.
Excelfile = {}
Excelfile = pick file ()...
best of luck!
