robot
Open Local Image In Expression Column
I am trying to import some images into a data table using an Expression Column in JMP12.  I am able to import an image from URL, but when I try the same technique on a local image, JMP12 will open the image rather than import it into the data table.  Does anyone have any idea what is causing this difference how to resolve it?  Thanks!
dt = New Table( "Image Test",
       Add Rows( 1 ),
       New Column( "Image from URL",
             Expression,
             Formula( New Image( Open( "http://eits.uga.edu/_resources/files/images/JMP_logo.png" ) ) )
       New Column( "Local Image",
             Expression,
             Formula( New Image( Open( "C:\Program Files\SAS\JMP\12\Samples\Images\tile.jpg" ) ) )
Craige_Hales
Re: Open Local Image In Expression Column
add the type argument to the open function.
Formula( New Image( Open( "$desktop/circle.png", "png" ) ) )
it will probably work OK even if you mix'n'match png, jpg, gif because the 2nd argument is mostly telling open not to pass the file to the OS default program but to turn it into an image if possible.
Craige
Craige_Hales
Craige
robot
Thanks Craige@JMP.  That works.
One complication is that if I replace the <type> argument with a column reference, it seems to no longer work.  Do you know why?
       Add Rows( 1 ),
       New Column( "Image Type", Character, Nominal, Set Values( {"png"} ) ),
             Expression,
             Formula(
                    New Image( Open( "http://eits.uga.edu/_resources/files/images/JMP_logo.png", :Image Type ) )
             Expression,
             Formula( New Image( Open( "$desktop/circle.png", :Image Type ) ) )
Craige_Hales
I'm not where I can look at the JMP source, but it's possible it is being treated like a keyword and not a variable.  I'm pretty certain you can just use "png" even for a .jpg.
Craige
try changing the formula to:
New Image( Open("http://cits.uga.edu/_resources/files/images/JMP-logo.png",Eval(Parse(char(:Image Type[Row()]) )) ) )
This should force the proper evaluation
robot
Thanks txnelson and Craige@JMP.  Both methods worked.
