‘New to using JMP? Hit the ground running with the Early User Edition of Discovery Summit – register now, free of charge.
How do I display Control Chart control limit in "Duration - hr:m" format?
I want to be able to display the control chart limits as a Duration but I can only display as numeric value. The column properties are defined as hr:m and I can display the axis, capability chart, etc. in hr:m but I am not even able to define a Control Limit manually in hr:m format. Does anybody know a work-around?
Thanks,
Chris
Re: How do I display Control Chart control limit in "Duration - hr:m" format?
I mocked up some data where the Process variable records time to finish a step. I applied a Duration format to the column. I analyzed Process with Control Chart Builder. It respects the format.
See the attached example.
Thanks for your reply. I think I must've been using one of the legacy control chart options which seems to have the issue
