nbhagroo
How do I create normal bars on my bar graph?
I am trying to make normal bars on my graph instead of dashes but I don't know where to adjust the setting. See picture attached. I have JMP version 17.
Re: How do I create normal bars on my bar graph?
Try changing your Y-axis modeling type to Continuous (currently you have Nominal). You can change it directly from graph builder by right-clicking on the bars on column selection or you could change them from data table by right clicking on column header.
Nominal:
Continuous:
Nominal:
Continuous:
